Custom front sway bar???, Coleman racing |
Andyrew |
Dec 10 2005, 10:25 PM
I really wouldnt mind putting a bigger front sway bar on my car, but since im plowing from understeer around town, im not really worrying about it..
BUT I am not rather liking the 350 or 500 I'd have to spend to get a good bar on my car. I currently have a stock bar up front, and 22mm T bars (ya, thats my kicker up front...) I was thinking that one of these coleman bars would work.. (IMG:http://www.colemanracing.com/catalog/images/pn658.jpg) They have the bar thickness from 3/4in to 1 1/2 in... Bar is 37.5 in long... Could it work? I know there will be fabrication involved (im cool with that.. only means more fun..) http://www.colemanracing.com/catalog/index...&sort=2a&page=1 Also, they have Just the bars at different lengths. But only at 1 1/4 thickness. Lengths from 32" to 43" and .125, .188, and .25 wall (whatever that means) Bars by themselves for 110 bucks. Any thoughts?? |
groot |
Dec 12 2005, 01:08 PM
Dis member Group: Members Posts: 896 Joined: 17-December 03 From: Michigan Member No.: 1,444 |
I use a standard length 37.5" bar. It's 7/8" diameter, but my motion ratios and front weight bias is mucho different than yours. If you're going down this path, I certainly wouldn't use the stock lever arms. You should also pay particular attention to how the stabilizer bar mounts to the body. In my case I used ball bearings and it doesn't bind like poly can.
From what you're describing you need less front bar, more rear bar or more front tire to get your car to turn. The downside to more rear bar is you'll lose traction. Have you played with tire pressures? |
