> crimpers, which work best
mightyohm
post Dec 12 2005, 11:15 PM
I want to invest in a nice set of crimpers for uninsulated crimp terminals. I want something better than the $9.99 radio shack style. Ratcheting would be nice if it makes a better crimp. Does anyone here have any suggestions? I don't want to spend over $100.
This is the kind I don't want:
(IMG:http://www.sunshinesolar.co.uk/ccp51/media/images/product_detail/crimper200.jpg)
Sorry I couldn't find a better pic.
lapuwali
post Dec 13 2005, 12:39 PM
Not another one!
QUOTE (andys @ Dec 13 2005, 10:00 AM)
For all the various wire sizes and connector combinations, why would you not want to solder and heat-shrink the connections? No need to buy expensive crimpers that will never cover the complete range of combinations anyway.
Military crimpers and crimp joints are completely engineered for a very specific combination of wire type, size, and connector. Many crimpers and connectors are even designed to crimp right over the insulated wire.
Andys
Because soldered connections are more brittle than crimped connections, and are not as reliable in a high-vibration environment. Soldered connections work great in electronics, but on loose wiring that flops around, vibrates, gets tugged on, etc, soldering really sucks. Again, this is what the OEM stuff does, and it's clearly good for 30 years of abuse. I've seen soldered connections fail in a few months of use on a car.
The number of combinations in a car harness really isn't that large. I have 18, 14, and 10g wire, with matching crimp-on connectors for each size. The ONLY wire you need outside of this is the one wire from the battery to the starter, which has to be 4 or 6g. The 10g is only used from the battery to the headlight area (all front lights) because of the long run. You could also use 2 14g wires instead and skip the 10g wire altogether. The 14 and 18 are used everywhere else, with most of the car is wired with 18g. The connectors also can accept and provide a good crimp on 2-3 sizes of wire, provided you have a good crimp tool.
jkeyzer   crimpers   Dec 12 2005, 11:15 PM
lagunero   Klein Tools at Home Depot. Made in USA and decent ...   Dec 12 2005, 11:36 PM
Cap'n Krusty   The ones shown aren't for non-insulated termin...   Dec 12 2005, 11:39 PM
markb   I picked one up for around $35.00 at our loca...   Dec 12 2005, 11:58 PM
lapuwali   I've found the ratcheting doesn't really m...   Dec 13 2005, 12:20 AM
jonwatts   I've been meaning to see what Halted has. They...   Dec 13 2005, 12:27 AM
J P Stein   StaCon (sp?) crimpers.   Dec 13 2005, 12:33 AM
jkeyzer   Whoa. Lots of good suggestions here! Am I ri...   Dec 13 2005, 01:12 AM
jonwatts   <...   Dec 13 2005, 01:15 AM
markb   Crimping for Fun and Profit? http:...   Dec 13 2005, 01:27 AM
blitZ   Crimping for Dummies   Dec 13 2005, 06:37 AM
maf914   The Joy of Crimping. http://...   Dec 13 2005, 07:47 AM
kwales   Ah, crimpers... The right ones are a joy to use. ...   Dec 13 2005, 09:00 AM
brownaar   The Klein 1005 crimper/cutter is the best general ...   Dec 13 2005, 09:05 AM
Air_Cooled_Nut   Jeff Bowlsby makes FI harnesses, what does he use?...   Dec 13 2005, 11:19 AM
Mueller   My father used to work for Hollingsworth so I have...   Dec 13 2005, 11:59 AM
andys   For all the various wire sizes and connector combi...   Dec 13 2005, 12:00 PM
lapuwali   <...   Dec 13 2005, 12:27 PM
lapuwali     Dec 13 2005, 12:39 PM
Porcharu   I'll go check Halted and Fry's at lunch fo...   Dec 13 2005, 01:57 PM
brownaar   Sorry, I spoke incorrectly. I have used the ...   Dec 13 2005, 01:59 PM
Jeffs9146     Dec 13 2005, 02:34 PM
J P Stein   I used to wire up electric boilers......had a pair...   Dec 13 2005, 02:43 PM
Porcharu   Those crimpers look just like the ones I got at OS...   Dec 14 2005, 04:33 PM
Spoke     Dec 14 2005, 06:38 PM
bwilless   The T&B set are my choice.   Dec 14 2005, 09:17 PM
jkeyzer   Well I took the advice of several folks here and b...   Dec 23 2005, 02:23 PM
jkeyzer   Here is a comparison of a crimp with the WT111M (t...   Dec 23 2005, 02:25 PM
McMark   Thanks for the followup Jeff. I'm gonna have ...   Dec 23 2005, 02:28 PM
ClayPerrine   Added to my list of "must have" tools. Thanks......   Dec 23 2005, 03:02 PM
bondo   <...   Dec 23 2005, 03:06 PM
lapuwali   Here's the crimp tool I use.   Dec 23 2005, 03:12 PM
lapuwali   Here's the crimp-on connector I use.   Dec 23 2005, 03:13 PM
lapuwali   Here's an example of a crimped connection. No...   Dec 23 2005, 03:16 PM
McMark   That's the kind I need to get James. I'm ...   Dec 23 2005, 03:16 PM
lapuwali   The tool I got at Radio Shack for something like ...   Dec 23 2005, 03:33 PM
McMark   I'm thinking that I should order a few differe...   Dec 23 2005, 03:42 PM
smooth_eddy   The T&B, Klein and Ideal are the best general use ...   Dec 23 2005, 04:10 PM
jkeyzer   James, the crimp terminals you have are the real d...   Dec 24 2005, 04:48 PM
chrisg   James, Do you have a part # for that radio shack c...   Dec 24 2005, 08:51 PM
lapuwali     Dec 24 2005, 09:05 PM
- Lo-Fi Version Time is now: 14th October 2026 - 03:08 AM
