| McMark |
Dec 8 2005, 01:05 AM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
The 125 HP, $5000 Type IV is now available! (IMG:style_emoticons/default/boldblue.gif)
Jake has chosen me to help make this engine a reality. This engine is a tried and true combo that Jake has developed over the years and all head work and assembly is done by me. Jake has created a special package for us that is not available on his website. I get the full package from him, and then I have your heads rebuilt and bolt it all together. This setup will produce about 125 hp with carbs or tunable EFI and 110 hp with stock D-Jet or L-Jet*. This engine is a 2056cc longblock with a special cam, full balance job and fully rebuilt heads will all new parts (seats, valves, guides, etc). This is not your run of the mill engine rebuild and this is not a "discount" engine. No corners are cut to reduce the price. Jake and I have worked out a deal that allows me to offer a QUALITY engine for only $5000. The balance job is Jake's "Improved Balance", the head parts are modified and tweaked for longevity, the lifters are proven to not go flat, and best of all the combo is proven to make power. Making power with the Type IV is all in the combo, as Jake has proven again and again. The engine comes to you already broken in and ready for you to bolt up your carbs or FI. You can use your stock heater boxes, although a header system will give you a 7% gain, and a Tangerine header system will get you a 15% boost. There is a $750 refundable core charge for a 2.0 core engine, or the following pieces: * Flywheel * 2.0 crank * 2.0 rods * Cooling fan with NO broken fins * 1.7 style rocker arms (13 mm adjuster nut) In addition, you will need to supply: * 1.8 or 2.0 heads that will be rebuilt. Condition is irrelevant and un-rebuilt heads are preferred. If you have heads that have already been "rebuilt" those heads will either be rebuilt again by me or if you insist on not having them rebuilt there will be no warranty on the engine. Cracks are acceptable and will be repaired during the rebuild process. * Case (any 914 case will work just fine) * Taco Plate + O-Ring * Oil Filter Console * Oil Bypass Springs/Pistons * Drain Plug * Distributor Drive Gear + Special Washer * Under Cylinder Engine Tin * Oil Cooler * Oil Cooler Thick Washers * Fan Mount + Bolts * Oil Baffle + Seals (OPTIONAL) * Oil Pressure Switch OR Pressure Sender * Oil Filler + Bail * Head Nuts + Washers * Through Bolts * Oil Pickup * Sump Cover * Endplay Shims * Distributor Clamp * Valve Covers + Bails * Rocker Shafts * Rocker Shaft Mounts These engines are a longblock only, no tin, no ignition, no exhaust and no installation. Everything on the engine is freshened/rebuilt, including the following: * Rebuilt and balanced set of crank and rods * Fully balanced rotating assembly that has been balance one step above what's normally available in his kits (extra value above buying a kit directly from Jake) * New pistons, rings, cylinders * Fully rebuilt heads with all new parts that are modified by Jake (new special seats, new special guides, new valves, new springs, new retainers, new keepers, any cracks repaired) * New hardware kit to replace worn out nuts and bolts * New cam and Jake's custom lifters that work * Custom cut ChroMoly pushrods * New clutch disk and pressure plate * Case galley plugs tapped for threaded inserts These engines come with a 6-month, 6k mile limited warranty. I will, of course, be standing behind my work, as always. Note that installing ignition and induction can be tricky and a poorly tuned engine can kill a perfectly good rebuild. These engines will take roughly 3-4 months to build from order to delivery depending on shipping times and how quickly I can receive the kits from Jake. These kits will not require an external oil cooler in most climates, but is very dependent on how well the engine is tuned. If you install one of my motors that runs hot, my first question will be the state of tune. Installation is available for additional cost, PM me for details. For those of you who don't have 2.0 engine core parts, I'm also offering a 1911cc longblock designed by Jake that makes 90 hp with carbs*. These engines go for $4500 which will save you $1250 off the 2056cc engine since you don't need the cores. This engine is comparable to a stock 2.0 and can use the stock 2.0 D-Jet. If you have any questions about either of these engines, feel free to ask me. Don't both asking Jake about these engines because he'll send you right back to me. These engines are fully designed by Jake, but all responsibility lies with me. *Horsepower numbers are quoted using a Mallory distributor, 2.0 heads and SSI 2.0 heater boxes. |
| blitZ |
Dec 15 2005, 04:40 PM
Beer please... ![]() ![]() ![]() ![]() Group: Members Posts: 2,223 Joined: 31-August 05 From: Lawrenceville, GA Member No.: 4,719 Region Association: South East States |
I noticed how much enthusiam was stirred by the Suby donut video thread, which was impressive. Maybe you could do some visual marketing with a before and after quarter mile at your local strip on their run what ya brung day.
McMark The $5k Engine Dec 8 2005, 01:05 AM
McMark I have one 2056 kit ready to go and as a promotion... Dec 8 2005, 01:07 AM
rdauenhauer So mark the 1911 is built of off what core parts a... Dec 8 2005, 01:35 AM
Jake Raby I'll only be weighing in here with this single... Dec 8 2005, 01:41 AM
Grimstead http://www.914world.com/bbs2... Dec 8 2005, 08:14 AM
McMark ... Dec 8 2005, 10:53 AM
McMark
lagunero
Hammy
Jake Raby Yet again this group has proven that you can liter... Dec 12 2005, 09:46 AM
Hammy now Jake... give it time. I'm interested and M... Dec 12 2005, 10:03 AM
spare time toys
Jake Raby Heck with as much interest this had you wuld have ... Dec 12 2005, 12:54 PM
Joe Ricard Well shoot I just happened to stumble on one of Ma... Dec 13 2005, 05:02 PM
fkelso I think the lukewarm response is simple, the price... Dec 13 2005, 11:48 PM
McMark There's only one way to get a cheaper engine, ... Dec 14 2005, 03:17 AM
Joe Ricard Mark honestly I don't know how many people hav... Dec 14 2005, 06:50 AM
Paul Illick Don't want to hijack the thread, but jeez Jake... Dec 14 2005, 07:29 AM
blitZ
fkelso Mark, sorry, I didn't mean to piss you off, I... Dec 14 2005, 11:04 PM
Jake Raby Paul,
Its just very baffling to receive emails an... Dec 15 2005, 12:17 AM
Grimstead
ewdysar For anyone that needs an engine built right now, t... Dec 15 2005, 02:52 PM
McMark Glad to hear guys. Thanks for the support.
We ... Dec 15 2005, 03:16 PM
McMark The $500 discount engine has been claimed. <... Dec 16 2005, 11:26 PM
chrisg curious what specs (ignition, exhuast, etc.) were ... Dec 17 2005, 10:45 AM
McMark 40 IDF carbs, Mallory distributor, 2.0 SSI heater ... Dec 17 2005, 11:38 AM
rick 918-S You couldn't have posted this in the general f... Dec 18 2005, 12:34 AM
McMark Rick, I couldn't post it there myself in good ... Dec 18 2005, 12:41 AM
lotus_65 i've been on the phone with jake since last fr... Dec 18 2005, 11:28 AM
GWN7 I didn't read this thread till Rick posted the... Dec 18 2005, 12:36 PM
IanStott Seriously interested Mark, should I PM you/phone y... Dec 20 2005, 07:36 PM
McMark PM me or give me a call at 707-738-5686. Or post ... Dec 21 2005, 02:21 AM
JmuRiz I hope you continue to get interest in these engin... Dec 21 2005, 12:28 PM
Rgreen914
McMark I'll still be offering them. h... Dec 22 2005, 03:30 AM
JmuRiz I wish there was one local for me to ride in...
I ... Dec 22 2005, 09:54 AM
Rob Ways Mark and Jake,
Your $5k engine sounds like ... Dec 22 2005, 10:29 PM
horizontally-opposed ... Dec 23 2005, 01:39 PM
McMark Who wants to be an adult? http://w... Dec 23 2005, 01:53 PM
Dan (Almaden Valley) Mark,
I am trying to decide if I want to attempt a... Dec 23 2005, 02:34 PM
McMark The $5k motor price is a longblock.
No tin... Dec 23 2005, 03:04 PM
Dan (Almaden Valley) "The $5k motor price is a longblock.
No tin... Dec 23 2005, 03:23 PM
McMark Here's what's included:
[*]Rebuilt set of... Dec 23 2005, 03:40 PM
YksKrad
Racer
McMark Longblock - $5500 (no core)
Distributor (Mall... Dec 27 2005, 08:04 PM
ThinAir914 WOW! I just stumbled across this because I sa... Dec 31 2005, 11:29 AM
ppickerell I also just ran across this and timing is wrong fo... Dec 31 2005, 01:46 PM
pnewman My 1.8 liter is developing some engine noise. and... Dec 31 2005, 08:26 PM
McMark
golfguy I'm assuming the reason people have not steppe... Jan 6 2006, 10:31 AM
Bleyseng some guys want a V8 in their 914 but most don... Jan 6 2006, 10:52 AM
YksKrad
McMark http://www.914world.com/bbs2/h... Jan 6 2006, 11:21 AM
rpmmaxxed Been a lil while longer since then. In 2 months or... Jan 7 2006, 01:04 PM
McMark Exactly. Let me know when you're ready and we... Jan 7 2006, 01:09 PM
TROJANMAN
McMark Too bad. I'm not pissed off anymore. No more... Jan 11 2006, 12:30 AM
Hammy How will these engines do in hot weather? (100+ de... Jan 11 2006, 02:28 AM
McMark Zack, the engine shouldn't have a problem with... Jan 11 2006, 03:57 PM
pnewman Who's a good source for a cht gauge and matchi... Jan 11 2006, 04:43 PM
lapuwali VDO makes a CHT gauge and sender. They're ava... Jan 11 2006, 05:19 PM
tat2dphreak ... Jan 11 2006, 07:10 PM
McMark I heard James (morphenspectra) was selling VDOs. Jan 11 2006, 09:27 PM
Hammy Mark.. you say you will be offering installs? Jan 11 2006, 10:38 PM
McMark Whoops, forgot to answer that part. ![]() ![]() |
Lo-Fi Version | Time is now: 30th November 2026 - 04:41 AM |
