Ride Height?, and autocross alignment settings? |
billd |
Dec 15 2005, 01:49 PM
Member Group: Members Posts: 327 Joined: 25-May 05 From: Palo Alto, CA Member No.: 4,145 |
What do people recommend for ride height and alignment settings for a 2.0L being used primarily for autocross. The rear ride height is constrained by the springs with the perch on the lowest "slot" in the Koni shock. For front height I was thinking of 125mm from the center of the torsion bar to the center of the spindle. This is 35mm lower than the stock 90mm. For camber I was thinking of -2 degrees in front and -2.5 degrees in back.
I've finally got the suspension put back together with 180# springs and Koni Sports in the back, 21mm torsion bars, Koni Sports, poly bushings, and turbo tie rods in front. Now I just need to set the alignment and get a decent set of tires (Faken 615s) on it. |
r_towle |
Dec 15 2005, 05:39 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
for camber...get as much as you can up front...
Without camber plates...I think 1.5 is the max...but your car is not the same as mine.... You can oval the holes out a little. The rear I would agree to about .5 more if you can. Then corner balance it. Rich |
Lo-Fi Version | Time is now: 1st June 2024 - 12:55 PM |
