fuel pump, for FI |
fuel pump, for FI |
bd1308 |
Dec 17 2005, 12:06 AM
Sir Post-a-lot Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 |
what fuel pump works with FI....that's not ten thousand dollars...?
I was thinking a bus fuel pump (input-and-output style) with some kind of pressure regulator using the return to the tank as the relief from the regulator. the pump is mounted in the front....by the steering rack. b |
Dave_Darling |
Dec 17 2005, 08:25 PM
Any 12V pump that can provide the appropriate amount of pressure (~3 Bar; ~45 PSI) and flow rate (I forget now, is it 50 liters/minute?) should work fine. Just make sure you can hook up the inlet and outlet fittings correctly to the fuel system, and mount it decently.
--DD |
Lo-Fi Version | Time is now: 9th June 2024 - 09:22 PM |
