993 3.6 guys...how do you adjust idle?, I want to raise the idle speed on my 3.6 |
nine14cats |
Dec 18 2005, 11:28 AM
Bill Pickering -- 914-6 GT aka....Leeloo Group: Members Posts: 2,618 Joined: 10-February 03 From: Campbell, CA Member No.: 287 Region Association: None |
My track car with the 3.6 in it idles around 750-800 RPM when warm. I want to raise the idle to 1000 to 1200 RPM to make engaging the 4 puck clutch/lightweight flywheel easier and also to take care of a harmonic reasonance with the car itself. There are several aluminum panels fabricated in the interior that just rattle like hell at the lower RPM's. You raise the RPM's over 1000 and it's nice and quiet in the cabin. (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif)
On the motor end there is a pin on the throttle lever but no provision for "tightening" or "shortening" the throttle cable, just a fitting at the end that doesn't adjust. Do I take up the slack on the gas pedal end to change idle speed? Or do I make some homemade circlips to shim the engine end of the cable? I don't see any other idle adjustment screw on any part of the motor. Thanks, Bill P. |
DonTraver |
Dec 18 2005, 12:04 PM
Senior Member Group: Members Posts: 829 Joined: 5-August 04 Member No.: 2,461 |
If I remember right the idle is set by the chip in the DME, to access it you need the Bosch Hammer, I've seen them go for about $2k on ebay. If you have the lightweight flywheel, you might have to get a new chip burned. They go for a couple of hundred.
The 964, 993, 996, etc engines controls are all electronic, not much you can do at home. I'm not sure about the carb'd 3.6 engines, probably need to remap the DME chip for them. On my 3.6 RSA, I just take it to the shop, there just isn't anything I can do at home with any of it. Stock idle is 800-850, no way can I change that with a mechanical adjustment. Good Luck, Don |
Lo-Fi Version | Time is now: 7th June 2024 - 01:04 PM |
