Pops out of 1st and 3rd |
goberserk |
Dec 28 2005, 05:21 PM
Newbie Group: Members Posts: 23 Joined: 26-November 05 From: Columbia, MD Member No.: 5,193 |
My tailshifter is popping our of 1st and 3rd. I can select them, but when I go to take the clutch out it grinds a little and pops into neutral. I just replaced all of the shifter bushings. It was doing it a bit last night, so I shortened the shifter bar via the linkage right in front of the firewall, down the access cover in the tunnel. That seemed to make it worse. I was able to get all the gears before I took it apart, it was vague, but it worked. I'm gonna go try making it longer (although I don't expect that to work) (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif)
goberserk |
Dec 28 2005, 06:36 PM
We fixed it. First we disconnected the rear sifter bar and put the trans in 1st to make sure the trans was ok; it was. Then we hooked up the rear bar only to make sure that wasn't impeding the shifter movement, it wasn't. So then we left the trans in first and put the shifter to the left and halfway into first. Then we tightened the jam nut and it seems to work. We can get all the gears no problem.
Lo-Fi Version | Time is now: 11th June 2024 - 08:39 AM |
