> L-jet wiring at coil
bd1308
post Dec 28 2005, 10:36 PM
Sir Post-a-lot
okay, so I know that L-jet uses the point pulses to fire injectors...my main relay is working, so what connections do i need at the coil?
i already have the tach wire, the point wire at the neg and nothing at the positive....
but i have a brown wire and two black wires joined to one both sets of wires having 12VDC on them....what gives?
b
bd1308
post Dec 29 2005, 12:34 PM
Sir Post-a-lot
guess i need to go to FLAPS.
b
bd1308   L-jet wiring at coil   Dec 28 2005, 10:36 PM
bd1308   and i also have a white FI wire coming way off and...   Dec 28 2005, 10:55 PM
Jeff Bowlsby   Britt- There is a series of 3 L-Jet diagrams unde...   Dec 28 2005, 11:21 PM
JOHNMAN   Your L-Jet is from a 1974. The double relay has a...   Dec 28 2005, 11:23 PM
bd1308   let's do this step by step then: A)where does...   Dec 28 2005, 11:30 PM
lapuwali   The white wire may go to the AAR. It's just s...   Dec 28 2005, 11:35 PM
bd1308   the yellow wire is regular sized wire...this harne...   Dec 28 2005, 11:39 PM
Jeff Bowlsby   L-Jet harnesses are completely different than D-Je...   Dec 28 2005, 11:51 PM
bd1308   mine is the 74 without the altitude compensator. ...   Dec 28 2005, 11:58 PM
JOHNMAN   (E) Red from the Dual relay -> To Batttery +12V (...   Dec 29 2005, 12:03 AM
bd1308   http://www.914world.com/bbs2/ht...   Dec 29 2005, 08:55 AM
bd1308   oh and Jeff thanks for the figures on your site, I...   Dec 29 2005, 09:00 AM
Flat VW   http://www.914world.com/bbs...   Dec 29 2005, 09:06 AM
bd1308   http://www.914world.com/bbs2/html/e...   Dec 29 2005, 09:08 AM
r_towle   Britt, What do you need. We have a 74 ljet all don...   Dec 29 2005, 09:41 AM
bd1308   i am like almost there..... im SO close.... I th...   Dec 29 2005, 09:48 AM
r_towle   Britt, neg coil green wire to points white wire to...   Dec 29 2005, 10:18 AM
bd1308   yeah but that wierd white or brown wire (from dual...   Dec 29 2005, 10:21 AM
r_towle   I have the big dual relay thing, and the smaller d...   Dec 29 2005, 10:24 AM
r_towle   tell me , when you lay the harness down where it i...   Dec 29 2005, 10:26 AM
bd1308   its not on the FI harness but off of the dual rela...   Dec 29 2005, 10:27 AM
Aaron Cox   pictures can help us help you... help us....help ...   Dec 29 2005, 10:38 AM
r_towle   ok, the entire wiring harness that enables your FI...   Dec 29 2005, 10:43 AM
Jeff Bowlsby   Does the yellow wire have a 1/4" wide long-blade m...   Dec 29 2005, 10:59 AM
bd1308   here's a pic. I dont even have spark now, and ...   Dec 29 2005, 11:10 AM
r_towle   start simple. Do you have power to the coil, key o...   Dec 29 2005, 11:20 AM
bd1308   i do have power to the coil, 12V at one end and th...   Dec 29 2005, 11:22 AM
r_towle   get a test light. I believe you may have power to...   Dec 29 2005, 11:34 AM
bd1308   i have two sets of everything, two coils and two d...   Dec 29 2005, 11:45 AM
r_towle   pull a plug wire, connect it to an old plug, groun...   Dec 29 2005, 11:50 AM
bd1308   okay i pulled a plug and voila! i have spark.....   Dec 29 2005, 12:05 PM
r_towle   so, with a test light. mount one side of test lig...   Dec 29 2005, 12:10 PM
bd1308   and does somebody have a relay board pic of a L-je...   Dec 29 2005, 12:11 PM
bd1308   teh spark was real yellow.... but i have spark. ...   Dec 29 2005, 12:13 PM
r_towle   ok, good, you have spark. now key on. open up the...   Dec 29 2005, 12:13 PM
bd1308   i had my fuel pump re-wired to the front trunk and...   Dec 29 2005, 12:18 PM
JOHNMAN   The relay boards are the same d-jet and l-jet. I ...   Dec 29 2005, 12:21 PM
bd1308   there was, I looked at it yesterday. anyway, with...   Dec 29 2005, 12:23 PM
r_towle   you will need to have the correct fuel pump instal...   Dec 29 2005, 12:25 PM
bd1308   the pump is already primed. heard the bubbles and ...   Dec 29 2005, 12:30 PM
r_towle   aar has vacuum hoses to it and the intake... all ...   Dec 29 2005, 12:33 PM
bd1308   guess i need to go to FLAPS. b   Dec 29 2005, 12:34 PM
bd1308   but okay, whats the deal with no power at the fuel...   Dec 29 2005, 12:35 PM
JOHNMAN   You could jumper a ground to make the fuel pump ru...   Dec 29 2005, 12:41 PM
r_towle   The deal is that you changed the wiring to the fue...   Dec 29 2005, 12:42 PM
bd1308   well the issue here isnt that my fuel pump doesnt ...   Dec 29 2005, 12:44 PM
r_towle   hang on for a sec.... that is the djet relay setu...   Dec 29 2005, 12:46 PM
bd1308   HUH? http://www.914world.com/bbs2/h...   Dec 29 2005, 12:49 PM
r_towle   no the relay board is the same. The LJET uses onl...   Dec 29 2005, 12:51 PM
JOHNMAN   B The relay boards are the same D-Jet or L-Jet. ...   Dec 29 2005, 12:56 PM
bd1308   at this present moment, no. I have the Haynes manu...   Dec 29 2005, 12:59 PM
bd1308   following this troubleshooting guide for L-jet mot...   Dec 29 2005, 01:10 PM
lapuwali   You should be able to test the relays themselves. ...   Dec 29 2005, 01:15 PM
r_towle   dont make it so complicated in your mind. to make...   Dec 29 2005, 01:22 PM
Mueller     Dec 29 2005, 01:27 PM
bd1308   now the battery is dead. this day is good. b   Dec 29 2005, 01:30 PM
jim912928   Easy way to check if your injectors are opening/cl...   Dec 29 2005, 01:39 PM
bd1308   uh, houston, no power to the injectors. b   Dec 29 2005, 01:48 PM
Mueller     Dec 29 2005, 01:59 PM
Mueller   for testing ONLY...... you could run a 12vdc + to...   Dec 29 2005, 02:02 PM
bd1308   EDIT! no power to resistor pack. now what? i...   Dec 29 2005, 02:03 PM
Mueller     Dec 29 2005, 02:04 PM
bd1308   <...   Dec 29 2005, 02:09 PM
JOHNMAN   Does the relay click when you turn the key on? Is...   Dec 29 2005, 02:13 PM
Mueller   is the AFM open? when the AFM opens, a microswitc...   Dec 29 2005, 02:14 PM
bd1308   if its the brown wire, then yes its grounded. I ju...   Dec 29 2005, 02:15 PM
bd1308   http://www.914world.com/bbs2/html/e...   Dec 29 2005, 02:22 PM
bd1308   I open the AFM and nada...nothin. Might as well b...   Dec 29 2005, 02:22 PM
JOHNMAN   B, Have you opened the PDF of the wiring diagram ...   Dec 29 2005, 02:27 PM
Mueller     Dec 29 2005, 02:30 PM
bd1308   okay...let me back up for a sec. I plugged the yel...   Dec 29 2005, 02:31 PM
bd1308   <...   Dec 29 2005, 02:34 PM
JOHNMAN     Dec 29 2005, 02:41 PM
bd1308   i had it correct via the haynes manual. I dunno. ...   Dec 29 2005, 02:44 PM
jim912928   don't be discouraged...once you get the kinks ...   Dec 29 2005, 02:49 PM
JOHNMAN   Do you get power at the AFM (pin 39) if you manual...   Dec 29 2005, 02:51 PM
bd1308   im trying not to...... it helps having people tha...   Dec 29 2005, 02:54 PM
bd1308   okay i think that if my battery wasnt borderline d...   Dec 29 2005, 03:02 PM
bd1308   http://www.914world.com/bbs2/html/e...   Dec 29 2005, 03:29 PM
JOHNMAN   You can get the fuel injectors to click when manua...   Dec 29 2005, 04:03 PM
bd1308   yep....click click click...it made me happy it di...   Dec 29 2005, 04:04 PM
JOHNMAN   I suppose that we should start right there. They ...   Dec 29 2005, 04:18 PM
bd1308   it checks out. ground is on 85 and power is on 86c...   Dec 29 2005, 04:30 PM
bd1308   its off to be recharge, i'll update when it ge...   Dec 29 2005, 05:06 PM
JOHNMAN   I'll try to help any way I can. I know that s...   Dec 29 2005, 06:09 PM
bd1308   okay... it fires. wont idle and doesnt like to p...   Dec 29 2005, 07:33 PM
JOHNMAN   Excellent! http://www.914...   Dec 29 2005, 07:42 PM
bd1308   got a Q for the peanut gallery.... what's up ...   Dec 29 2005, 07:53 PM
r_towle   Way to go Britt, You will love a solid well tune...   Dec 29 2005, 07:59 PM
JOHNMAN   I don't know if it would run too rich. It is ...   Dec 29 2005, 08:03 PM
bd1308   im working on it... the big step here is to get t...   Dec 29 2005, 08:03 PM
bd1308   maybe i have the fuel pressure regulator backwards...   Dec 29 2005, 08:06 PM
grasshopper   sorry...slight hijack here... but i just bought a ...   Dec 29 2005, 08:08 PM
bd1308   mine was all in the wiring...three hours ago i was...   Dec 29 2005, 08:12 PM
JOHNMAN   grasshopper, You may want to start a new thread, ...   Dec 29 2005, 08:44 PM
bd1308   another thread would be a excellent idea...   Dec 29 2005, 08:49 PM
rdauenhauer   Britt WOW http://www.914world.com/...   Dec 29 2005, 09:12 PM
bd1308   well it seems like its stubling and rough running,...   Dec 29 2005, 09:53 PM
bd1308   rich, thanks buddy. I have the plenum in a box for...   Dec 29 2005, 09:54 PM
JOHNMAN   Have you double checked that the injector groups a...   Dec 29 2005, 10:34 PM
- Lo-Fi Version Time is now: 11th July 2025 - 10:16 AM
