> Engine out today, a couple of pics and questions
rjkavanagh
post Dec 31 2005, 08:44 PM
Finally got to drop the 2.0 out of my '75' today. Followed Mark D's instructions in the tech article and was able to remove it by myself. Great instructions, thanks Mark. Had to drop it because 2 of the bolts in the fan had worked their wat out and the 3rd sheared off. I don't know how I got so lucky but, the fan came through undamaged. The only issue is that there is about a 1/4" of the 3rd stud broken off in the gland on the front of the crank. I tried pulling that gland but it's really on there so, I thought I'd ask for advice from the group. Here's a couple of pictures.
Pic 1
Aaron Cox
post Dec 31 2005, 10:55 PM
Professional Lawn Dart
QUOTE (r_towle @ Dec 31 2005, 09:52 PM)
I have broken every easy out I have ever tried...
Then it is really hard to drill out.
now I just drill it to the threads and re-tap it...its easier and less time consuming...
If you get an easy out tip stuck in there...you need a really good bit to drill that out...not the normal hardware store bit...
Rich
wierd...never had a failure....
just went nice and slow.....
i like the dremel idea...also
rjkavanagh   Engine out today   Dec 31 2005, 08:44 PM
rjkavanagh   Pic 2   Dec 31 2005, 08:45 PM
rjkavanagh   Pic 3   Dec 31 2005, 08:46 PM
rjkavanagh   Thanks for your help in advance. - Rob   Dec 31 2005, 08:46 PM
Travis Neff   Got a dremel? grind a slot in the bolt for a flat...   Dec 31 2005, 09:01 PM
r_towle   I would remove the bolt, remove the flange.... Br...   Dec 31 2005, 10:44 PM
Aaron Cox   drill a pilot hole... drill a larger hole. EZ out...   Dec 31 2005, 10:47 PM
r_towle   I have broken every easy out I have ever tried... ...   Dec 31 2005, 10:52 PM
Aaron Cox   <...   Dec 31 2005, 10:55 PM
V6914   <...   Jan 2 2006, 03:10 AM
Bleyseng   use a boron bit to drill a easyout with. super har...   Jan 2 2006, 10:11 AM
9146986   <...   Jan 2 2006, 11:32 AM
- Lo-Fi Version Time is now: 8th July 2025 - 11:46 PM
