billd |
Member ![]() ![]() Group: Members Posts: 327 Joined: 25-May 05 From: Palo Alto, CA Member No.: 4,145 ![]() |
My steering wheel just developed a significant wobble. It moves several degrees left/right and up/down. The bolt holding the wheel to the splines is tight. The splined shaft itself is moving. I suspect that the bearings that hold the steering shaft have loosened up. Does anyone know the procedure for tightening them?
TravisNeff |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region ![]() ![]() |
There are 4 allen bolts that hold the column to the tub right behind the dash. Check those first, you usually cat get a 1/2 turn on them and will reduce quite a bit of that wobble, then onto bearings.
Lo-Fi Version | Time is now: 16th June 2024 - 09:35 AM |
