Dash blinkers not working |
watsonrx13 |
Jan 5 2006, 05:31 PM
Advanced Member Group: Members Posts: 2,735 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States |
The front and rear blinkers are working correctly, but the dash lights aren't. When I turn the left ones on, nothing is lit in the dash. When I turn the right ones on, both blinkers in the dash are lit. After searching the archives, it appears to be the flasher relay in the fuse panel. Attached is the fuse panel, is the relay that I need to replace the small square one? Also, notice that this relay has a wire that is connected to two of the prongs, is this correct?
-- Rob Attached image(s) |
watsonrx13 |
Jan 5 2006, 05:50 PM
Here's a spare relay that I took out of my parts car, can I swap it? Also, notice that there is a prong missing, is this a problem?
Andy, where on the tach would I add the ground wire? -- Rob Attached image(s) |
Lo-Fi Version | Time is now: 16th June 2024 - 07:40 AM |
