> What is the Club's opinon of $ worth, of The Beast -- sans engine and trans
nine14cats
post Jan 6 2006, 01:05 AM
Bill Pickering -- 914-6 GT aka....Leeloo
I would appreciate inputs from the 914Club collective as to what The Beast would fetch on the open market if I were to sell her without an engine and transmission. I'm talking fair market value.
Here are the specs:
*TonyC cage with Petty bar, tied in at the suspension points both front and rear
*Camber boxes up front
*Tube Frame rear
*Front and Rear suspension points raised 2 inches in the frame done right on a Celette bench
*Sheridan Narrow Body Kit Front and Rear
*Fiberglass Hoods
*Fuel Safe fuel cell with fuel starvation resevoir
*Fresh Powder Coated tub (white)
*Fresh Exterior paint by Yeaman Autobody (Yellow, Orange, or Red)
*WEVO shifter for 915 or 901 (Take your pick, I've got both)
*Smart Racing 27mm Front AR bar
*Advanced Design Ground Control 2 way adjustable shocks coil overs all 4 corners
*Spring rates TBD (I've got a bunch)
*23mm master cylinder
*Rebuilt pedal cluster
*JRZ 4 piston brake calipers front and rear
*Cockpit adjustable brake bias valve
*Front Oil Cooler big enough for a 993 3.6
*20 quart front mount oil tank (Partick Motorsports)
*Carbon Fiber rear wing with 0,3, and 7 degree angle adjustments
*Smart Racing quick disconnect steering wheel hub (Momo steering wheel included)
*Mueller's Roller Bearing suspension
*Rich Johnson bulkhead -6 mount
*Sparco EVO2 Racing Seats
*Teamtech 5 point harnesses
*Fire bottle
*Lexan rear window
*(8) 16x10 Diamond Racing Wheels with Hoosier slicks (23.5x11.5x16)
*Rebuilt steering rack
This will be a nicely done track car that can also be a TTOD car at local AX's (narrow body) and fresh paint, suspension, and tires.
I am debating how far to take it. Obviously, if I keep it, I have to sell Fritz. If I keep Fritz, I have to sell The Beast. And there lies the rub. Do I go to the added expense of adding a drive train, or is it a push on cost vs. recovered cost?
I have a 901 MSX box and no motor right now, but it may be just the same to sell the above sans motor and transaxle.
What do you think the car is worth as stated in the above configuration?
Thanks in advance for everyone's help!
Bill P.
VegasRacer
post Jan 6 2006, 01:48 AM
ELVIRA
Figure about a quarter of what you have into the parts.
I dunno. 10, 12k.
nine14cats   What is the Club's opinon of $ worth   Jan 6 2006, 01:05 AM
VegasRacer   Figure about a quarter of what you have into the p...   Jan 6 2006, 01:48 AM
redshift   Probably half that, in this depressed market... <...   Jan 6 2006, 01:51 AM
jonwatts   Hi Bill, Are you having second thoughts? I was un...   Jan 6 2006, 02:06 AM
nine14cats   Hi John, Purchase price of the car included the b...   Jan 6 2006, 02:22 AM
McMark   I was thinking $10k as well. I think one maj...   Jan 6 2006, 02:37 AM
VegasRacer   Bill - I can understand the need to get out on the...   Jan 6 2006, 02:59 AM
GWN7   Generally projects get $0.25 on the $1.0...   Jan 6 2006, 09:35 AM
nocones   I have to agree with the others, likely in the 10k...   Jan 6 2006, 10:27 AM
rick 918-S     Jan 6 2006, 10:38 AM
andys   Unfortunately, this kind of stuff normally falls i...   Jan 6 2006, 10:49 AM
ppickerell   Bill, I have been watching auctions and listings f...   Jan 6 2006, 11:01 AM
nine14cats   I've been doing the same thing as far as watch...   Jan 6 2006, 11:34 AM
Dan (Almaden Valley)   Hmmm.... MSX gear box http://www.91...   Jan 6 2006, 11:36 AM
nine14cats   http://www.914world.com/bbs...   Jan 6 2006, 11:40 AM
J P Stein   I would do which ever leaves me in the best financ...   Jan 6 2006, 12:13 PM
Mueller   think Scott would want to buy it back if he sells ...   Jan 6 2006, 12:32 PM
nine14cats   Hi Mike, Scott has another tube frame 914 that is...   Jan 6 2006, 12:48 PM
neo914-6   http://www.914world.com/bbs2/h...   Jan 6 2006, 09:51 PM
drew365
- Lo-Fi Version Time is now: 9th July 2025 - 12:57 PM
