| redshift |
Jan 6 2006, 09:28 PM
Bless the Hell out of you! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 |
I hope I haven't destroyed my synchros double clutching for a mile... freaking shitty mechanic.
M |
| Dave_Darling |
Jan 7 2006, 05:12 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,335 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
Did you use one of the standard 13mm wrench-size nuts? Betcha did--sounds like what happened to me when I did that. You neet to use an M7 nut, 11mm wrench size. Two of them, tightened against each other, and that sucka won't go anywhere! I tired Nyloc, but it didn't hold well enough. --DD |
redshift Clutch cable Jan 6 2006, 09:28 PM
TROJANMAN uhhhh,,,,,,isn't this garage fodder? Jan 7 2006, 01:18 AM
redshift Oh my gawd... it's in the garage..
I changed ... Jan 7 2006, 04:35 PM
r_towle so you have a loose nut, a stripped nut, one nut t... Jan 7 2006, 04:48 PM
bd1308 its a wierd nut....smaller than the generic 10mm n... Jan 7 2006, 04:49 PM
redshift I can't be on both ends at once.. I heard a qu... Jan 7 2006, 05:00 PM
Headrage Aren't you double nutting it? Jan 7 2006, 05:02 PM
bd1308 chopsticks work great...
four of them with twist ... Jan 7 2006, 05:03 PM
redshift Gotta BE DA TUBE
Dark:45 out right now.. can you ... Jan 7 2006, 05:55 PM
bd1308 if you need to limp it to a shop, just keep it in ... Jan 7 2006, 05:58 PM
redshift hahahah RIGHT
M Jan 7 2006, 06:01 PM
bd1308 http://www.914world.com/bbs... Jan 7 2006, 06:06 PM
Pinepig http://www.914world.com/bb... Jan 7 2006, 10:57 PM
redshift So, can I epoxy this thing in?
htt... Jan 7 2006, 11:02 PM
Headrage <... Jan 7 2006, 11:27 PM
redshift Look, I just need one moron to tell me it's ok... Jan 8 2006, 12:37 AM
GWN7 Just drill down from the top of the tunnel and use... Jan 8 2006, 12:41 AM
redshift Under Canadian law? HAH! Try and get that to s... Jan 8 2006, 12:45 AM
Pinepig <... Jan 8 2006, 01:05 AM
redshift Some fool... any fool... help.
htt... Jan 8 2006, 01:23 AM
bd1308 miles adhesive will work just fine.
my car is hel... Jan 8 2006, 01:50 AM
redshift The munky has swung!
Ok Brit, be it upon your... Jan 8 2006, 04:51 AM
redshift HEY! ARE THERE ANY OTHER M7 11mm NUTS ANYWHERE... Jan 19 2006, 01:28 PM
redshift http://www.914world.com/bbs2/h... Jan 19 2006, 01:36 PM
r_towle miles,
you can feel the clutch tube with the end ... Jan 19 2006, 01:39 PM
redshift NONONO!
I JUST need M7 11mm nuts, or somethin... Jan 19 2006, 02:00 PM
"7" If the problem isn't the tube - but just the n... Jan 19 2006, 02:12 PM
r_towle look on the lever/arm that makes the lights go up ... Jan 19 2006, 02:15 PM
redshift No joy... good lord have mercy... I want to kill ... Jan 19 2006, 02:19 PM
r_towle year of car...
I will go find you a nut...
Ther... Jan 19 2006, 02:23 PM
redshift http://www.914world.com/bbs2/... Jan 19 2006, 02:35 PM
r_towle NP, better than TV some days...
R Jan 19 2006, 02:57 PM
redshift Success! Thanks for looking around Mr. Rich. I... Jan 19 2006, 04:14 PM
Dave_Darling The nuts that hold the rocker arm shafts onto the ... Jan 19 2006, 08:37 PM
Bleyseng ![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:36 PM |
