| bondo |
Jan 8 2006, 09:17 PM
Practicing my perpendicular parking ![]() ![]() ![]() ![]() Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California |
I set the spring with a metal plate on it next to a wall. I made a mark on the wall at the top of the plate. I added 25 lbs, 50 lbs, and 230 lbs (me), and marked the wall accordingly. I then did the math to calculate pounds per inch, and I get around 120 lbs per inch. (for example, it deflected 1.9 inches when I stood on it)
All the measurements started with a nearly completely unloaded spring, which is not the situation it will see in a car. Is the spring effect linear, or do I need to install them in a 914 and see how much it dips when I jump in the rear trunk? |
| bondo |
Jan 9 2006, 10:00 AM
(IMG:http://www.914world.com/bbs2/html/emoticons/icon_bump.gif)
Can anyone at least tell me if I'm way off? Or suggest a closer spring tester? (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
bondo Checking spring rate Jan 8 2006, 09:17 PM
SirAndy Jan 8 2006, 10:38 PM
Borderline That's the principle. You should be in the ba... Jan 9 2006, 10:09 AM
bondo ... Jan 9 2006, 11:01 AM
ppickerell Aaron is right. Get the spring under some load at ... Jan 9 2006, 11:29 AM
bondo Jan 9 2006, 12:09 PM
ppickerell Ooops, My bad, the springs I make are so f'in ... Jan 9 2006, 12:27 PM
bondo Ok, I tried it with more weight. I added weight in... Jan 17 2006, 04:17 PM
Mueller Jan 17 2006, 04:31 PM
bondo <... Jan 17 2006, 04:53 PM
Mueller Jan 17 2006, 04:57 PM
bondo <... Jan 17 2006, 05:29 PM
bondo I think I may have figured out where the 1/4" come... Jan 17 2006, 06:59 PM
bondo Ok, here's the pic.. this is 300 lbs. Half the... Jan 17 2006, 07:28 PM
bondo Ok, I measured the spring and used this formula to... Jan 20 2006, 06:19 PM
bondo Here is the graph of the data. (I did the graph a ... Jan 20 2006, 06:22 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 03:35 PM |
