> Running wires from engine to interior.., routing thru longs?
DougC
post Jan 12 2006, 02:33 PM
I need to run some wires from the engine compartment to the interior, for my oil press and temp guages. I assume I can run them through the heater tube connections (I'm running headers) but would like to be sure. Is there anything inside that would stop me from sending them forward to the front tube area (under the fuse panel)..
Also, on the same note..will I need to connect them to the fuse panel? what fuses are free for such items? All advice is appreciated.
Doug C
2-OH!
post Jan 12 2006, 02:44 PM
No, Heater tubes would be great but you may want to seal the entry point somehow to prevent moisture...
Fuses depend on what amperage you plan to use on the line...But for gauges (don't draw much amperage) 8's would be my guess
2-OH!
- Lo-Fi Version Time is now: 1st August 2025 - 01:56 PM
