> Wanted: local D-Jet owner to test new product, trigger point replacement for upgrades
Mueller
post Jan 16 2006, 03:04 PM
914 Freak!
Currently D-Jet owners are limited to using the stock distributor which besides being 30 years old, does not have an easy method of changing the timing curve for those that want to optimize thier ignition.
For those that have been on the board for a while, I made an optical circuit that fit inside an aftermarket Mallory billet distributor (I'm sure it's work just as well in a billet MSD distributor)
Our (Fiid and I) new design has no moving parts, just 1 wire to the coil with the other 3 wires pluging into the factory engine harness to bypass the mechanical points inside the D-Jet distributor.
Ideally for testing purposes keeping the stock distributor with the trigger points intact would be a good idea in case a problem did occur with the prototype unit and you could just unplug our modual and hookup the factory connectors easily.
DanT
post Jan 16 2006, 03:10 PM
Going back to the Dark Side!
Would my totally stock EFI and distributor in my 1974 2.0L Track/AX car work? (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
Mueller   Wanted: local D-Jet owner to test new product   Jan 16 2006, 03:04 PM
Dan (Almaden Valley)   Would my totally stock EFI and distributor in my 1...   Jan 16 2006, 03:10 PM
SLITS   Ok Jake Mike, how much do we have to pay to test i...   Jan 16 2006, 03:12 PM
Mueller     Jan 16 2006, 03:23 PM
jimkelly   I'm ignorant : ) Are you looking for carbed ...   Jan 16 2006, 05:44 PM
Mueller   ...   Jan 16 2006, 05:55 PM
Dan (Almaden Valley)   So what exactly would be involved with this testin...   Jan 16 2006, 06:25 PM
Mueller     Jan 16 2006, 06:40 PM
Dan (Almaden Valley)   Mike, As to "how long it will last" I was referr...   Jan 16 2006, 06:52 PM
Mueller   http://www.914world.com/bbs2/...   Jan 17 2006, 09:30 AM
r_towle   If you need cold weather testing...let me know... ...   Jan 17 2006, 10:23 AM
Mueller   ...   Jan 17 2006, 12:19 PM
mikerose   Well hell if I need a car you have that old 911 I ...   Jan 17 2006, 02:04 PM
Howard   If I'm local enough, send me one. Stock 2.0 F...   Jan 17 2006, 05:34 PM
Gint   I'm not local. http://ww...   Jan 17 2006, 06:17 PM
redshift   Ok GOODY! Cause I want that DIZZY OUT OF THERE...   Jan 17 2006, 06:29 PM
Jake Raby   Glad to hear this Mike... I don't have a D Jet...   Jan 17 2006, 06:39 PM
- Lo-Fi Version Time is now: 23rd September 2025 - 02:28 AM
