| bondo |
Jan 8 2006, 09:17 PM
Practicing my perpendicular parking ![]() ![]() ![]() ![]() Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California |
I set the spring with a metal plate on it next to a wall. I made a mark on the wall at the top of the plate. I added 25 lbs, 50 lbs, and 230 lbs (me), and marked the wall accordingly. I then did the math to calculate pounds per inch, and I get around 120 lbs per inch. (for example, it deflected 1.9 inches when I stood on it)
All the measurements started with a nearly completely unloaded spring, which is not the situation it will see in a car. Is the spring effect linear, or do I need to install them in a 914 and see how much it dips when I jump in the rear trunk? |
| bondo |
Jan 17 2006, 06:59 PM
I think I may have figured out where the 1/4" comes from.. one of the things you do when calculating spring rate is count the "free coils". Setting the spring on something flat gives it more free coils than when the top and bottom most coils are more supported by the spring saddle and hat. If I can figure out a way to do it, I'll try again using the spring saddle and hat.
bondo Checking spring rate Jan 8 2006, 09:17 PM
SirAndy Jan 8 2006, 10:38 PM
bondo http://www.914world.com/bbs2/ht... Jan 9 2006, 10:00 AM
Borderline That's the principle. You should be in the ba... Jan 9 2006, 10:09 AM
bondo ... Jan 9 2006, 11:01 AM
ppickerell Aaron is right. Get the spring under some load at ... Jan 9 2006, 11:29 AM
bondo Jan 9 2006, 12:09 PM
ppickerell Ooops, My bad, the springs I make are so f'in ... Jan 9 2006, 12:27 PM
bondo Ok, I tried it with more weight. I added weight in... Jan 17 2006, 04:17 PM
Mueller Jan 17 2006, 04:31 PM
bondo <... Jan 17 2006, 04:53 PM
Mueller Jan 17 2006, 04:57 PM
bondo <... Jan 17 2006, 05:29 PM
bondo Ok, here's the pic.. this is 300 lbs. Half the... Jan 17 2006, 07:28 PM
bondo Ok, I measured the spring and used this formula to... Jan 20 2006, 06:19 PM
bondo Here is the graph of the data. (I did the graph a ... Jan 20 2006, 06:22 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 03:36 PM |
