yarin |
'14-X'in FOOL ![]() ![]() ![]() Group: Members Posts: 988 Joined: 13-May 03 From: Guttenberg, NJ Member No.: 693 Region Association: North East States ![]() |
This is a "'73 1.7L L-jet setup" i'm considering buying. I see a 4 bolt pattern, however my carbed 2.0 has a 3 bolt pattern. Can these injection runners be drilled to fit my heads?
Thanks Attached image(s) ![]() |
yarin |
Yes you guys are correct. It is a D-jet system, my mistake. I'm building a megasquirt system and want to use some stock components for now just to get things going. So will this stock D-jet 1.7 setup bolt to my 2.0 heads assuming i drill an extra hole in the middle? I will be using the following stock components: runners, injectors, fuel rail, intake plenum, fuel pump, fuel pressure regulator I've read that stock 1.7 injectors work much better than 2.0 injectors due to minimum pulse width limitations on the 2.0s. 1.7 injectors certainly flow enough for a slightly modified 2.0. Thanks! |
Lo-Fi Version | Time is now: 1st August 2025 - 12:12 PM |
