yarin |
'14-X'in FOOL ![]() ![]() ![]() Group: Members Posts: 988 Joined: 13-May 03 From: Guttenberg, NJ Member No.: 693 Region Association: North East States ![]() |
This is a "'73 1.7L L-jet setup" i'm considering buying. I see a 4 bolt pattern, however my carbed 2.0 has a 3 bolt pattern. Can these injection runners be drilled to fit my heads?
Thanks Attached image(s) ![]() |
yarin |
OK. Sounds like 1.7 injectors and 2.0 plenum and runners are the way to go for now. So i'm looking for 1.7 injectors and 2.0 plenum and runners, fuel pump, fuel rail, pressure regulator. I don't want to use a stock throttle body, i'll find something from volvo or elsewhere. The rest of the parts i can find GM OEM like the TPS, Fidle solenoid or GM IAC, air temp sensor, then Wideband. |
Lo-Fi Version | Time is now: 1st August 2025 - 11:59 AM |
