> Clutch cable, came loose?
redshift
post Jan 6 2006, 09:28 PM
Bless the Hell out of you!
I hope I haven't destroyed my synchros double clutching for a mile... freaking shitty mechanic.
M
r_towle
post Jan 19 2006, 01:39 PM
Custom Member
miles,
you can feel the clutch tube with the end of your fingers through the heater lever hole....
sitting in the car, with the heater lever out of the way (the one next to the shifter)
push the clutch in and out...if you feel the tube move or rattle, you then need to figure out where that is happening.
Brad did a detailed article on how to fix it..
If you cant weld, look at that article, you will see the measurements to locate where the tube is in the middle tunnel.
I am sure you could cut open the tunne in the same location and fasten/glue the tube in at that location to solve that problem...
The nut...I would say look for one in the front as your ground for the lights...
Or possibly you could use one from the windshield wiper assembly...
I seem to remember those being an odd size
If what you need to do is take your car, with the stripped nut to a shop, I might suggest that you epoxy the existing nut in the correct position, and let it harden for 24 hrs....that might let you shift a dozen times or so before it gets loose.
Rich
redshift   Clutch cable   Jan 6 2006, 09:28 PM
TROJANMAN   uhhhh,,,,,,isn't this garage fodder?   Jan 7 2006, 01:18 AM
redshift   Oh my gawd... it's in the garage.. I changed ...   Jan 7 2006, 04:35 PM
r_towle   so you have a loose nut, a stripped nut, one nut t...   Jan 7 2006, 04:48 PM
bd1308   its a wierd nut....smaller than the generic 10mm n...   Jan 7 2006, 04:49 PM
redshift   I can't be on both ends at once.. I heard a qu...   Jan 7 2006, 05:00 PM
Headrage   Aren't you double nutting it?   Jan 7 2006, 05:02 PM
bd1308   chopsticks work great... four of them with twist ...   Jan 7 2006, 05:03 PM
Dave_Darling   <...   Jan 7 2006, 05:12 PM
redshift   Gotta BE DA TUBE Dark:45 out right now.. can you ...   Jan 7 2006, 05:55 PM
bd1308   if you need to limp it to a shop, just keep it in ...   Jan 7 2006, 05:58 PM
redshift   hahahah RIGHT M   Jan 7 2006, 06:01 PM
bd1308   http://www.914world.com/bbs...   Jan 7 2006, 06:06 PM
Pinepig   http://www.914world.com/bb...   Jan 7 2006, 10:57 PM
redshift   So, can I epoxy this thing in? htt...   Jan 7 2006, 11:02 PM
Headrage   <...   Jan 7 2006, 11:27 PM
redshift   Look, I just need one moron to tell me it's ok...   Jan 8 2006, 12:37 AM
GWN7   Just drill down from the top of the tunnel and use...   Jan 8 2006, 12:41 AM
redshift   Under Canadian law? HAH! Try and get that to s...   Jan 8 2006, 12:45 AM
Pinepig   <...   Jan 8 2006, 01:05 AM
redshift   Some fool... any fool... help. htt...   Jan 8 2006, 01:23 AM
bd1308   miles adhesive will work just fine. my car is hel...   Jan 8 2006, 01:50 AM
redshift   The munky has swung! Ok Brit, be it upon your...   Jan 8 2006, 04:51 AM
redshift   HEY! ARE THERE ANY OTHER M7 11mm NUTS ANYWHERE...   Jan 19 2006, 01:28 PM
redshift   http://www.914world.com/bbs2/h...   Jan 19 2006, 01:36 PM
r_towle   miles, you can feel the clutch tube with the end ...   Jan 19 2006, 01:39 PM
redshift   NONONO! I JUST need M7 11mm nuts, or somethin...   Jan 19 2006, 02:00 PM
"7"   If the problem isn't the tube - but just the n...   Jan 19 2006, 02:12 PM
r_towle   look on the lever/arm that makes the lights go up ...   Jan 19 2006, 02:15 PM
redshift   No joy... good lord have mercy... I want to kill ...   Jan 19 2006, 02:19 PM
r_towle   year of car... I will go find you a nut... Ther...   Jan 19 2006, 02:23 PM
redshift   http://www.914world.com/bbs2/...   Jan 19 2006, 02:35 PM
r_towle   NP, better than TV some days... R   Jan 19 2006, 02:57 PM
redshift   Success! Thanks for looking around Mr. Rich. I...   Jan 19 2006, 04:14 PM
Dave_Darling   The nuts that hold the rocker arm shafts onto the ...   Jan 19 2006, 08:37 PM
Bleyseng
- Lo-Fi Version Time is now: 2nd April 2026 - 01:36 PM
