> Clutch cable, came loose?
redshift
post Jan 6 2006, 09:28 PM
Bless the Hell out of you!
I hope I haven't destroyed my synchros double clutching for a mile... freaking shitty mechanic.
M
Bleyseng
post Jan 19 2006, 11:06 PM
Aircooled Baby!
QUOTE (Dave_Darling @ Jan 19 2006, 06:37 PM)
The nuts that hold the rocker arm shafts onto the cylinder head are M7, but you don't wanna remove those... Not sure of any others off the top of my head.
The "11" is the size of the wrench that you use. The full spec is something like M7x0.5 (where the 0.5 means 0.5mm between threads). I don't know if 0.5 is the correct thread pitch or not--but there is one common one, and that's the one you use.
Get the nuts from your local hardware store. It doesn't matter which size wrench you need to use on them, as long as the threaded hole is correct for the application.
--DD
unless you have upgraded those POS small ones that strip easy to the bigger studs. (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif)
(IMG:http://www.914world.com/bbs2/html/emoticons/popcorn[1].gif) Hi Miles
redshift   Clutch cable   Jan 6 2006, 09:28 PM
TROJANMAN   uhhhh,,,,,,isn't this garage fodder?   Jan 7 2006, 01:18 AM
redshift   Oh my gawd... it's in the garage.. I changed ...   Jan 7 2006, 04:35 PM
r_towle   so you have a loose nut, a stripped nut, one nut t...   Jan 7 2006, 04:48 PM
bd1308   its a wierd nut....smaller than the generic 10mm n...   Jan 7 2006, 04:49 PM
redshift   I can't be on both ends at once.. I heard a qu...   Jan 7 2006, 05:00 PM
Headrage   Aren't you double nutting it?   Jan 7 2006, 05:02 PM
bd1308   chopsticks work great... four of them with twist ...   Jan 7 2006, 05:03 PM
Dave_Darling   <...   Jan 7 2006, 05:12 PM
redshift   Gotta BE DA TUBE Dark:45 out right now.. can you ...   Jan 7 2006, 05:55 PM
bd1308   if you need to limp it to a shop, just keep it in ...   Jan 7 2006, 05:58 PM
redshift   hahahah RIGHT M   Jan 7 2006, 06:01 PM
bd1308   http://www.914world.com/bbs...   Jan 7 2006, 06:06 PM
Pinepig   http://www.914world.com/bb...   Jan 7 2006, 10:57 PM
redshift   So, can I epoxy this thing in? htt...   Jan 7 2006, 11:02 PM
Headrage   <...   Jan 7 2006, 11:27 PM
redshift   Look, I just need one moron to tell me it's ok...   Jan 8 2006, 12:37 AM
GWN7   Just drill down from the top of the tunnel and use...   Jan 8 2006, 12:41 AM
redshift   Under Canadian law? HAH! Try and get that to s...   Jan 8 2006, 12:45 AM
Pinepig   <...   Jan 8 2006, 01:05 AM
redshift   Some fool... any fool... help. htt...   Jan 8 2006, 01:23 AM
bd1308   miles adhesive will work just fine. my car is hel...   Jan 8 2006, 01:50 AM
redshift   The munky has swung! Ok Brit, be it upon your...   Jan 8 2006, 04:51 AM
redshift   HEY! ARE THERE ANY OTHER M7 11mm NUTS ANYWHERE...   Jan 19 2006, 01:28 PM
redshift   http://www.914world.com/bbs2/h...   Jan 19 2006, 01:36 PM
r_towle   miles, you can feel the clutch tube with the end ...   Jan 19 2006, 01:39 PM
redshift   NONONO! I JUST need M7 11mm nuts, or somethin...   Jan 19 2006, 02:00 PM
"7"   If the problem isn't the tube - but just the n...   Jan 19 2006, 02:12 PM
r_towle   look on the lever/arm that makes the lights go up ...   Jan 19 2006, 02:15 PM
redshift   No joy... good lord have mercy... I want to kill ...   Jan 19 2006, 02:19 PM
r_towle   year of car... I will go find you a nut... Ther...   Jan 19 2006, 02:23 PM
redshift   http://www.914world.com/bbs2/...   Jan 19 2006, 02:35 PM
r_towle   NP, better than TV some days... R   Jan 19 2006, 02:57 PM
redshift   Success! Thanks for looking around Mr. Rich. I...   Jan 19 2006, 04:14 PM
Dave_Darling   The nuts that hold the rocker arm shafts onto the ...   Jan 19 2006, 08:37 PM
Bleyseng
- Lo-Fi Version Time is now: 2nd April 2026 - 01:36 PM
