V8 FUEL PUMP, Where do you guys put it? |
marks914 |
Jan 20 2006, 10:32 AM
Senior Member Group: Members Posts: 845 Joined: 9-October 04 From: the motor city Member No.: 2,912 Region Association: None |
Now that my conversion is over 3 years old, I am going through and re-working some things that I could have done better. The first thing is my fuel pump. I am using an el-cheapo pump that is mounted in the engine compartment down low where the fuel lines come out of the firewall. I was using a Holley Red, but it was so noisy and it died anyway.
The reason for the rework is that the pump sometimes seems to go dry, espescially after driving on the freeway for a while and after sitting, espescially when its hot. I think its a case of fuel starvation and vapor lock. I am planning on moving the pump to the front trunk area, closer to the tank. What else is everyone doing? I also would like to find a quiet pump. My car is a 72, so there was not a pump in the front to begin with, that's why I started with the pump in the rear. The other thing I am getting ready to re do is my cooling system. I just had a 14x27 dual pass two 1.5 inch core radiator fabricated by a local hot rod shop for $275. The owner said this radiator should be able to cool a big-block with 1800CFM. Alot cheaper than those other places. Thanks Mark |
914GT |
Jan 20 2006, 11:52 AM
Senior Member Group: Members Posts: 1,100 Joined: 11-October 04 From: Tucson Member No.: 2,923 Region Association: Southwest Region |
Here's where I mounted mine. Yeah, I know ... I'm just being a troublemaker. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Attached image(s) |
Lo-Fi Version | Time is now: 11th June 2024 - 12:18 AM |
