That was Easy, Ordered from TYPE IV store |
Joe Ricard |
Jan 23 2006, 09:37 AM
CUMONIWANNARACEU Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
Put a Mallory Dizzy on order. Quick simple nice transaction.
Now I need a better coil that will go with the dizzy and my Mallory 6A ignition box. 8mm Magnacore plug wires. any suggestions? 8.0 compression and will be going up. .500 lift 300 duration cam, 40IDF's 32 mm vents, tall intakes, Tangerine EVO 5/8" header with silencer. engine will be balanced, and already has dual valve springs so I want to rev it. HARD! If you recommend Bosch blue please justify your reason. |
Joe Ricard |
Jan 23 2006, 10:12 AM
Ballast resistor when running a 6A box?? Hmm where did I put that instruction book for the Mallory box. As I see it both + and - terminals from the doil come off the box not the 12V switched power of the car.
12V switched power now goes to the red wire of the Mallory box. |
Lo-Fi Version | Time is now: 2nd June 2024 - 08:14 PM |
