> How Long to Seat Rings, 2056
MarkV
post Jan 23 2006, 03:23 PM
Fear the Jack Stands
I have about 1,500 miles on the engine refresh. Noticed that it puffs blue smoke when I shift gears. Checked the compression and it is about 130# on all four cylinders. Ran non-detergent oil for the first 500 miles then changed to 20W-50 Castrol. Changed it again yesterday and went with 10W-30. It was nasty black and looked like it had 8,000 miles on it instedaed of 1,000.
Got the cylinders and Hastings rings from Jake. Had Len Hoffman do the heads with new valves, guides, springs & retainers, welded up plug holes to 12mm. The CR is 8.6:1. Running DRLA 40's w/ 32mm vents, 55 idle jets.
The car runs great but seems like the rings should have sealed by now. (IMG:http://www.914world.com/bbs2/html/emoticons/blowup.gif)
MarkV
post Jan 23 2006, 04:07 PM
If anything it is running lean. I have been going back and forth between 55 & 60 idle jets. The 55 that I am running now pop a little through the carbs when it is cold. Once the temperature comes up it runs better. It runs at around 300 degrees.
Is there anything I can do at this point? Can I take it back apart and re-hone the cylinders? Seems like 130# of compression is low it had 145# with the old dished 94's.
MarkV   How Long to Seat Rings   Jan 23 2006, 03:23 PM
Jake Raby   They generally seat in 500 miles, sometimes in col...   Jan 23 2006, 03:58 PM
MarkV   If anything it is running lean. I have been going ...   Jan 23 2006, 04:07 PM
Travis Neff   How are you driving the car? easy, or like you st...   Jan 23 2006, 10:01 PM
MarkV   I have been winding the dog pee pee out of it sinc...   Jan 23 2006, 10:20 PM
MarkV   Anyone ever tried this quick seat stuff?   Jan 23 2006, 10:22 PM
Twystd1   You used a ball hone with 240 grit and hastings ri...   Jan 24 2006, 12:00 AM
Brett W   You could always do the comet trick.
- Lo-Fi Version Time is now: 8th July 2025 - 08:06 PM
