MarkV |
Fear the Jack Stands ![]() ![]() ![]() Group: Members Posts: 1,493 Joined: 15-January 03 From: Sunny Tucson, AZ Member No.: 154 Region Association: None ![]() |
I have about 1,500 miles on the engine refresh. Noticed that it puffs blue smoke when I shift gears. Checked the compression and it is about 130# on all four cylinders. Ran non-detergent oil for the first 500 miles then changed to 20W-50 Castrol. Changed it again yesterday and went with 10W-30. It was nasty black and looked like it had 8,000 miles on it instedaed of 1,000.
Got the cylinders and Hastings rings from Jake. Had Len Hoffman do the heads with new valves, guides, springs & retainers, welded up plug holes to 12mm. The CR is 8.6:1. Running DRLA 40's w/ 32mm vents, 55 idle jets. The car runs great but seems like the rings should have sealed by now. (IMG:http://www.914world.com/bbs2/html/emoticons/blowup.gif) |
Brett W |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,859 Joined: 17-September 03 From: huntsville, al Member No.: 1,169 Region Association: None ![]() ![]() |
You could always do the comet trick. (IMG:http://www.914world.com/bbs2/html/emoticons/happy11.gif)
Be very careful when you re-hone as you will open the cylinders up even more and have more problems getting the rings to seal. What main jets are you running? What do your sparkplugs look like? What does the inside of your oil filter look like. |
Lo-Fi Version | Time is now: 8th July 2025 - 08:05 PM |
