> Metal Ready, necessary?
rjames
post Jan 25 2006, 04:41 PM
I'm made of metal
They guy at the local auto body shop said that metal ready wasn't necessary (probably because he was out of the stuff) before using POR15 as long as I did a good job of grinding all of the rust out.
This doesn't sound correct as I'll never be able to grind and clean up ALL of the rust particles...
However, I've seen the instructions for the Metal Ready stuff, and it sounds like a big mess. Is there another product that's less messier that will do the same thing (assuming I need it)? Rubbing alcohol? (at least that stuff will evaporate on it's own).
Also, I've got areas where I won't be able to wash the metal ready stuff out of if I apply it (center tunnel comes to mind). I can't just spray Metal Ready in there because it's an acid and eventually will destroy the metal- I have to be able to wash the stuff out. So do I just try and coat with POR15 using some sort of 'rag-on-a-pole' method??
New pics of the longs, rust etc:
http://www.914world.com/bbs2/index.php?act=...&hl=metal+ready
Since I have a couple of small areas to weld later, can I grind of the POR15 easily (or easily enough) when the time comes to weld those areas? (ie: holes due to rust)
rjames
post Jan 25 2006, 07:08 PM
I'm made of metal
Your 2 cents is welcomed! Seriously!
Jack plate: Cut it off. Cut rotted metal out around that area back far enough to get rid of rotted metal and into good metal. Weld in new sheet metal.
Do I really need the jack plate? I was thinking about cutting it out and leaving it off.
rjames   Metal Ready   Jan 25 2006, 04:41 PM
bondo   Jasco metal etch is pretty similar and much cheape...   Jan 25 2006, 04:44 PM
airsix   Messy but effective. Don't take shortcuts IMHO...   Jan 25 2006, 04:50 PM
Rand   According to the company, POR15 is "designed for a...   Jan 25 2006, 04:51 PM
tat2dphreak   if you are using real POR-15, use Metal ready too....   Jan 25 2006, 04:54 PM
rjames   I'm leaning towards some kind of rust inhibito...   Jan 25 2006, 04:57 PM
Bartlett 914   I can't say for sure if you need metal ready o...   Jan 25 2006, 05:00 PM
TimT   Use white vinegar http://www....   Jan 25 2006, 05:02 PM
lapuwali   There are some who would say the opposite: use Met...   Jan 25 2006, 05:34 PM
Eric_Shea   Never used it (Metal Ready). I've only applie...   Jan 25 2006, 06:01 PM
SirAndy   ...   Jan 25 2006, 06:44 PM
McMark   Metal Ready leaves a zinc layer as well.   Jan 25 2006, 06:48 PM
Rrrockhound     Jan 25 2006, 06:50 PM
Rand     Jan 25 2006, 07:04 PM
  Jan 25 2006, 07:25 PM
sgomes
  Jan 26 2006, 12:14 AM
Rand   I don't see the point of trying to spray Metal...   Jan 26 2006, 01:09 AM
sgomes   <...   Jan 26 2006, 08:22 AM
Vacca Rabite   <...   Jan 26 2006, 08:32 AM
maf914     Jan 26 2006, 09:40 AM
SirAndy     Jan 26 2006, 01:18 PM
SirAndy     Jan 26 2006, 01:20 PM
Rand   I'm with you Andy - not arguing... But it seem...   Jan 26 2006, 01:46 PM
SirAndy     Jan 26 2006, 02:16 PM
Rand   Nothing like real-world proof. Gotta go with what ...   Jan 26 2006, 02:33 PM
rjames   What about the Marine Clean degreaser stuff they s...   Jan 26 2006, 02:38 PM
SirAndy     Jan 26 2006, 02:57 PM
SirAndy     Jan 26 2006, 03:00 PM
Rand   I know Ospho does not continue eating metal. After...   Jan 26 2006, 03:11 PM
rjames   Yes, big thanks to all who are contributing to thi...   Jan 26 2006, 03:58 PM
SirAndy     Jan 26 2006, 04:05 PM
sgomes
  Jan 26 2006, 04:09 PM
Rrrockhound     Jan 26 2006, 06:36 PM
kwales   I remove all loose rust, clean the surface well an...   Jan 26 2006, 07:32 PM
swl   I can't resist wading in here and risking the ...   Jan 26 2006, 07:55 PM
SirAndy     Jan 26 2006, 08:04 PM
swl   ouch andy - my brain dumped all that complex inter...   Jan 26 2006, 08:20 PM
rjames   Wow, excellent discussion folks.   Jan 27 2006, 12:33 AM
kwales   Shannon, the hard black stuff is magnetite or conv...   Jan 27 2006, 09:36 AM
kwales   Ooops, forgot the picture....   Jan 27 2006, 09:38 AM
sgomes   I think I can speak for everyone, This thread roc...   Jan 27 2006, 09:51 AM
- Lo-Fi Version Time is now: 6th July 2025 - 02:35 PM
