carbon fiber experts?? |
r_towle |
Jan 26 2006, 05:00 PM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
So,
Carbon fiber is 6 times stronger than steel. here are my thoughts. take off the outer rocker. Fix the rust with new steel. sandblast the area Lay on a layer of CF directly to the inner long front to back, wrap in to the bottom and top horizontal layers. when using CF and bonding it to steel, I have read that you would use an epoxy resin to bond it directly to the steel, so it would be the same as putting por 15 on steel (por 15 is an epoxy layer) So, thoughts? plus, minus? Rich |
alpha434 |
Jan 26 2006, 07:10 PM
My member number is no coincidence. Group: Members Posts: 3,154 Joined: 16-December 05 From: Denver, CO Member No.: 5,280 Region Association: Rocky Mountains |
Yes. They bend. But they wouldn't bend so much as to crack the CF off.
And por-15 bonds to metal. That's going to be important. And maybe once every couple of seasons, you'll have to change up the CF layer. |
Lo-Fi Version | Time is now: 10th June 2024 - 06:30 AM |
