| rpmmaxxed |
Feb 3 2006, 09:50 AM
Member ![]() ![]() Group: Members Posts: 387 Joined: 24-May 05 From: Oceanside, CA Member No.: 4,140 Region Association: Southern California |
All was running perfect on the 1.7, up until yesterday. I look down, and notice all guauges are dead.
I release my brake pedal, and all guages perk up, but slightly off. Night falls, I turn heater/defroster on, and suddenly my rpm guage is off by 1,000's, my gas guage is hovering above zero (I know I have 3/4 tanks). This has happened once before, for just a couple minutes, and went away. That was months ago, not its happening again, and not goin away. At the touch of my brake pedal, all guauges drop dead, my blinkers do not function anymore, and the backlight on my heater knob is no longer working. Anyone that can help, please do. |
| ClayPerrine |
Feb 3 2006, 10:00 AM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,542 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
check the fuses..... the gauge fuse will cause all sorts of weird stuff if it is blown.
But frankly, this sounds like a bad ground. Check and clean all the ground points in the car, starting with the one above the fuse box..... |
rpmmaxxed Electrical Mayhem in 1 Day? Feb 3 2006, 09:50 AM
markb Start with the most common culprit and clean all y... Feb 3 2006, 09:54 AM
Dr Evil Yup, look at your tranny ground strap, too. Any re... Feb 3 2006, 09:56 AM
rhodyguy the tach go to 0, and gas gauge goes to nothing wh... Feb 3 2006, 10:03 AM
redshift You kicked it a fuse out!
M Feb 3 2006, 10:08 AM
Series9 I would check the master ground next to the fuse b... Feb 3 2006, 10:08 AM
HarveyH Had a similar problem a couple of years ago, I thi... Feb 3 2006, 10:13 AM
rpmmaxxed Will check all of the above mentioned in a short w... Feb 3 2006, 10:34 AM![]() ![]() |
Lo-Fi Version | Time is now: 3rd March 2026 - 01:27 PM |
