weber tuning, questions |
r_towle |
Feb 6 2006, 03:41 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
ok,
So I have one rich and one perfect plug on one side... I will use the idle mixture screw to adjust this condition... What is the air bypass screw for, where do you guys set it, and how does it change the way the carb tunes?? I was having some sooty exhaust, so I checked the floats..perfect..if not just a tad lean...11mm which is ok with me... Rich |
lapuwali |
Feb 6 2006, 05:08 PM
Not another one! Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 |
When adjusting the idle mixture screws, go slow. Turn 1/8th, wait a few seconds, repeat. There's some lag between the time to adjust and the time the engine note changes. So, turn in 1/8th at a time, pause, until the engine note changes, then back out 1/8th, pausing, until the engine note changes again. Repeat until you get it just rich of stumbling. Start each one about 3 turns out from lightly bottomed.
Lo-Fi Version | Time is now: 2nd June 2024 - 10:39 AM |
