5-Lug 911 Conversion, Caliper differences? |
Spoke |
Feb 8 2006, 04:43 PM
Jerry Group: Members Posts: 6,989 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
I'm doing a 5-lug conversion for my new 914 and need some help understanding the differences in front 911 calipers. I've seen "A", "M", and "S" calipers referred to. What's the difference? Which one(s) should I try to get? Lastly, anybody got a set of front struts/rotors/calipers?
Thanks, Spoke PS: If this topic has been covered before, please forward the link to me. |
Aaron Cox |
Feb 8 2006, 05:09 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
QUOTE(TimT @ Feb 8 2006, 03:53 PM) A & S are the same sized caliper, S is aluminum, A is steel (iron), the aluminum calipers flex under heavy braking, also the A & S have 3.5" mounting bolt spacing. These have a larger pad than the M M calipers have a smaller pad than the A & S, are iron bodied, and have 3.00" mounting bolt spacing. Any of those calipers will work fine, S calipers command a premium I have a comlplete 911 front end M calipers with vented discs ( this was from a 911 T with S package) couldnt have summed it up better meself... i find that M calipers with an agressive pad are more than adequate to make my car stand on the nose....... S calipers are $$$$$$$$$$$$$$$ An m caliper front end is anywhere from 200- 500 an A caliper front end is 500-800 Add a couple hundred to the above for S calipers.... |
Lo-Fi Version | Time is now: 3rd June 2024 - 10:03 AM |
