Need some open diff measurements ASAP!, anyone have a 901 and 915 carrier out? |
rick 918-S |
Feb 8 2006, 01:06 PM
Hey nice rack! -Celette Group: Members Posts: 20,494 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
I've been searching this board and others boards for a week now and I've yet to come up with a solid answer. I'm attempting to try a Phantom Grip limited slip unit in my 901. They only list them for the 915 on their web site.
Ok, one more time on this thing, Does anyone know if the 901 and 915 OPEN diff use the same carrier? Q. 1) Can some check part numbers? Q. 2) Does anyone have both units apart in there shop? This is what I'm looking for. Q. 3) I need to know if the space between the spyder gears is the same. Q. 4) And if the spyder shaft is the same diameter. If the shaft is the same diameter, and the spacing between the gears is the same, the carrier won't matter. I'm attempting to save the cost of setting up a different (915) carrier in my case. A side by side comparision would be the best. Bondo (Royce) has a 901 apart and is willing to get the measurements. So anyone have a 915 they can measure? |
bondo |
Feb 8 2006, 11:56 PM
Practicing my perpendicular parking Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California |
Ok, it sounds like you don't need this anymore, but here's what I've got.
Part number: 914 332 212 00 Spider gear shaft: 18mm diameter Distance between the spider gears: 45 mm (this measurement may be off a tiny but as I couldn't get the correct inside measurement bits of the digital calipers between them, so I had to use the outside measurement bits and line it up by eye) |
Lo-Fi Version | Time is now: 12th June 2024 - 06:02 AM |
