| yarin |
Feb 9 2006, 11:14 AM
'14-X'in FOOL ![]() ![]() ![]() Group: Members Posts: 988 Joined: 13-May 03 From: Guttenberg, NJ Member No.: 693 Region Association: North East States |
I bought 3/8" and 5/16" (2 each 60" and 40") brake lines to use for replacing my plastic fuel lines. I'm following the pelican fuel line replacement how to. However i'd rather not use a 90 deg bend and increase the # of fitting in the system.
Can I just bend the brake lines using proper tooling? The auto part store sells one for around $30. With this significantly reduce the flow? Has anyone here followed the pelican how to? Is the 60" line long enough to feed through the tunnel and leave 2-3" at the firewall side for this 90 deg bend? Thanks |
| yarin |
Feb 9 2006, 12:47 PM
not planning on it.
what's the hardest part of doing the job with the engine in? snaking the lines through the tunnel or mounting against the firewall? I don't recall if the engine mount bar gets in the way. does it? If I tie some wire to the stock lines before pulling them out, can't i pull the new lines from the front(with a little force of course)? |
yarin Bending Brake lines Feb 9 2006, 11:14 AM
Vacca Rabite I have been considering this myself and also had a... Feb 9 2006, 12:17 PM
zymurgist I used mild steel brake lines in 60" and 40" lengt... Feb 9 2006, 12:25 PM
yarin ... Feb 9 2006, 12:40 PM
mcbain77 yarin - are you planning on taking the engine out? Feb 9 2006, 12:45 PM
mcbain77 Actually I wanted to know because I am planning on... Feb 9 2006, 12:58 PM
yarin <... Feb 9 2006, 01:09 PM
zymurgist Feb 9 2006, 02:13 PM
yarin How about this one?
http://www.jcwhitney.com/auto... Feb 10 2006, 07:57 AM
zymurgist Looks good to me. For $6 that's even les... Feb 10 2006, 10:28 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 06:41 PM |
