> not starting..., I know it's not the starter...
tat2dphreak
post Sep 6 2003, 03:31 PM
stoya, stoya, stoya
today I was trying to crank the 1.8 engine that's in the tailshifter right now... the 1.7 will go into it soon, but I wanted to see if the 1.8 was in good shape and could be sold as a good running engine... instead of a complete core...
fuel pump kicks one when I turn the key on, but the starter did nothing... so I pulled it off and put my spare(also was in question) on... it didn't work either... so I put the one that I know works on from my other engine... still nothing...
I took the original starter to Autozone... it only needed 4 volts to turn like a champ...
so, now that I wasted all day trying 3 starters and replacing all of the fuses(2-3 were missing) I am back a square 1!
how can I check the ignition-switch on the column? what else do I need to check to diagnose the problem? also, is there a reference somewhere that can tell me what size fuses go where, so I can double check this? it's not in the haynes wiring diagrams, where I thought is should be....
thanks!
Brad Roberts
post Sep 7 2003, 12:56 AM
914 Freak!
Here is what I do... pull the cover off the 14 pin connector at the REAR of the relay board. Look for the yellow wire(this yellow wire goes to the starter solenoid). Run a jumper wire from the battery over to that yellow wire... and touch it. If the starter turns over.. its something between that connecter and the column. Basically I work backwards to diganose problems like this (oh..I dont actually run a jumper wire from the battery.. I know which pins are hot on the relay board and I run a small short jumper to the yellow wire)
B
tat2dphreak   not starting...   Sep 6 2003, 03:31 PM
Jeffs9146   Use a screw driver to jump the terminals on the so...   Sep 6 2003, 03:56 PM
URY914   Make sure you have the engine ground strap attache...   Sep 6 2003, 05:39 PM
tat2dphreak   ground strap is fine, but the battery may be a lit...   Sep 6 2003, 08:29 PM
SirAndy   relay   Sep 6 2003, 09:01 PM
Brad Roberts   Here is what I do... pull the cover off the 14 pin...   Sep 7 2003, 12:56 AM
tat2dphreak   ok, screwdriver test: positive, the starter turne...   Sep 7 2003, 06:00 PM
Brad Roberts   Andy was on crack. There is NO relay in the car th...   Sep 8 2003, 12:14 AM
- Lo-Fi Version Time is now: 15th June 2026 - 03:40 AM
