> Ignition woes continue
BenNC
post Sep 7 2003, 02:40 PM
OK guys I've got at least two things going on. I finally got a good switch (fourth times a charm), but I'm still not starting.
1. I get power going into the relay board, but not coming out. What happens to the juice once it enters the board? I cleaned up the pins and connectors, but I still do not get power out consistantly.
2. When I do get power out the starter turns like a champ, but I am not getting spark all the time. This is a new trick. Is this associated with number 1, or a whole new problem.
Thanks
TheCabinetmaker
post Sep 7 2003, 05:16 PM
I drive my car everyday
intermitent spark would suggest a short somewhere. Replace the relays with the ones from the headlight motors. Check voltage at the coil. Make sure all electrical connections are clean and tight.
- Lo-Fi Version Time is now: 9th June 2026 - 02:28 AM
