| tat2dphreak |
Sep 6 2003, 03:31 PM
stoya, stoya, stoya ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
today I was trying to crank the 1.8 engine that's in the tailshifter right now... the 1.7 will go into it soon, but I wanted to see if the 1.8 was in good shape and could be sold as a good running engine... instead of a complete core...
fuel pump kicks one when I turn the key on, but the starter did nothing... so I pulled it off and put my spare(also was in question) on... it didn't work either... so I put the one that I know works on from my other engine... still nothing... I took the original starter to Autozone... it only needed 4 volts to turn like a champ... so, now that I wasted all day trying 3 starters and replacing all of the fuses(2-3 were missing) I am back a square 1! how can I check the ignition-switch on the column? what else do I need to check to diagnose the problem? also, is there a reference somewhere that can tell me what size fuses go where, so I can double check this? it's not in the haynes wiring diagrams, where I thought is should be.... thanks! |
| SirAndy |
Sep 8 2003, 12:20 AM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,483 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
QUOTE(Brad Roberts @ Sep 7 2003, 11:14 PM) Andy was on crack. There is NO relay in the car that makes the starter work.. he *might* have meant the solenoid (his english is lacking in content). well, then you might want to add one ... (IMG:style_emoticons/default/wink.gif) relay board could be toast. check the underside and see if the plastic is brittle and broken ... Andy |
tat2dphreak not starting... Sep 6 2003, 03:31 PM
Jeffs9146 Use a screw driver to jump the terminals on the so... Sep 6 2003, 03:56 PM
URY914 Make sure you have the engine ground strap attache... Sep 6 2003, 05:39 PM
tat2dphreak ground strap is fine, but the battery may be a lit... Sep 6 2003, 08:29 PM
SirAndy relay Sep 6 2003, 09:01 PM
Brad Roberts Here is what I do... pull the cover off the 14 pin... Sep 7 2003, 12:56 AM
tat2dphreak ok,
screwdriver test: positive, the starter turne... Sep 7 2003, 06:00 PM
Brad Roberts Andy was on crack. There is NO relay in the car th... Sep 8 2003, 12:14 AM
SirAndy ![]() ![]() |
Lo-Fi Version | Time is now: 15th June 2026 - 03:40 AM |
