| BenNC |
Sep 7 2003, 02:40 PM
Member ![]() ![]() Group: Members Posts: 140 Joined: 7-February 03 From: Cary, NC Member No.: 267 |
OK guys I've got at least two things going on. I finally got a good switch (fourth times a charm), but I'm still not starting.
1. I get power going into the relay board, but not coming out. What happens to the juice once it enters the board? I cleaned up the pins and connectors, but I still do not get power out consistantly. 2. When I do get power out the starter turns like a champ, but I am not getting spark all the time. This is a new trick. Is this associated with number 1, or a whole new problem. Thanks |
| Brad Roberts |
Sep 8 2003, 12:34 AM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
Ben..
The relay boards are known to fail. Oh.. word to the wise.. remove the POS coil wire when you are going to have the key in the on position for any longer than 5 minutes (even with points). Bypass the relay board and basically hot wire the coil to the battery.. see if it runs correctly. Then you will know whether or not it is the relay board. B |
BenNC Ignition woes continue Sep 7 2003, 02:40 PM
BenNC and in a recent development, my Pertronix unit jus... Sep 7 2003, 04:04 PM
vsg914 Ben, what do mean by burned up? be more specific p... Sep 7 2003, 04:10 PM
ChrisReale Probably left the ignition on, like it says not to... Sep 7 2003, 04:11 PM
BenNC Burned up as in smoke pouring out of the distibuto... Sep 7 2003, 04:27 PM
vsg914 Yes, you burned it up with the ignition on. Put th... Sep 7 2003, 04:31 PM
ChrisReale pertronix says not to leave the ignition on for mo... Sep 7 2003, 04:32 PM
BenNC OK, one problem chalked up to the faulty nut behin... Sep 7 2003, 05:00 PM
vsg914 intermitent spark would suggest a short somewhere.... Sep 7 2003, 05:16 PM
rhodyguy chris, forget an implied warrentee, remember the o... Sep 8 2003, 07:11 AM![]() ![]() |
Lo-Fi Version | Time is now: 9th June 2026 - 02:30 AM |
