| BenNC |
Sep 7 2003, 02:40 PM
Member ![]() ![]() Group: Members Posts: 140 Joined: 7-February 03 From: Cary, NC Member No.: 267 |
OK guys I've got at least two things going on. I finally got a good switch (fourth times a charm), but I'm still not starting.
1. I get power going into the relay board, but not coming out. What happens to the juice once it enters the board? I cleaned up the pins and connectors, but I still do not get power out consistantly. 2. When I do get power out the starter turns like a champ, but I am not getting spark all the time. This is a new trick. Is this associated with number 1, or a whole new problem. Thanks |
| rhodyguy |
Sep 8 2003, 07:11 AM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,252 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
chris, forget an implied warrentee, remember the old "no return on electrical parts". i think lawrence can attest to this as well. i went through 4 or 5 days of misery with my NEW compufire. as geoff wrote,"nice kevin, put in the points and start the car". 10 minutes and it was vrooom.
kevin |
BenNC Ignition woes continue Sep 7 2003, 02:40 PM
BenNC and in a recent development, my Pertronix unit jus... Sep 7 2003, 04:04 PM
vsg914 Ben, what do mean by burned up? be more specific p... Sep 7 2003, 04:10 PM
ChrisReale Probably left the ignition on, like it says not to... Sep 7 2003, 04:11 PM
BenNC Burned up as in smoke pouring out of the distibuto... Sep 7 2003, 04:27 PM
vsg914 Yes, you burned it up with the ignition on. Put th... Sep 7 2003, 04:31 PM
ChrisReale pertronix says not to leave the ignition on for mo... Sep 7 2003, 04:32 PM
BenNC OK, one problem chalked up to the faulty nut behin... Sep 7 2003, 05:00 PM
vsg914 intermitent spark would suggest a short somewhere.... Sep 7 2003, 05:16 PM
Brad Roberts Ben..
The relay boards are known to fail. Oh.. wo... Sep 8 2003, 12:34 AM![]() ![]() |
Lo-Fi Version | Time is now: 9th June 2026 - 02:28 AM |
