> subaru ecu/ems, subaru engine electronics
ModPR3
post Feb 23 2006, 06:34 PM
subie guys need your help again. after finding out that a 911 engine rebuild cost over 8k the subie or v8 path is looking good again. if i ran the 2002-2004 wrx 2.0 turbo motor what do i do about the engine control unit or engine management. can the engine be run with the stock subaru ecu or does it have to be switched out to a standalone unit. if the stock ecu can be used, how hard is it to wire into the 914. thanks.
TonyAKAVW
post Feb 23 2006, 08:29 PM
That's my ride.
Well, there are a number of electrical engineers on this board, and once a few more people have gone through the wiring, there will be even more to help with that. I've already helped another member here figure out some wiring stuff with their Subaru swap and wouldn't mind helping out others.
Making up plans or directions is a bit tricky because of all the variations in engines, ECUs, etc. They are all different, but in the end there is a lot that is common.
Once I actually get my car running and all the troubleshooting done I will do my best to publish the schamatics I have made, etc. But that will only work for a 2001 EJ25. 95% will be identical in concept to other Subaru engines, but pinouts on the ECU, colors of wires, things like that will be different. All of those things are easy to figure out by reading through a manual.
On the other hand you can go buy a Link ECU and they even sell harnesses. That requires far less work.
-Tony
ModPR3   subaru ecu/ems   Feb 23 2006, 06:34 PM
lapuwali   The stock ECU can be used. There's at least o...   Feb 23 2006, 06:40 PM
Mueller   Here you go: Possum Link ...new board that replac...   Feb 23 2006, 06:50 PM
bondo   <...   Feb 23 2006, 06:57 PM
lapuwali     Feb 23 2006, 07:02 PM
Mueller     Feb 23 2006, 07:06 PM
TonyAKAVW   Type IV cheap? yeah right! At least most S...   Feb 23 2006, 07:21 PM
TonyAKAVW   The wiring harness 'conversion' isn't ...   Feb 23 2006, 08:02 PM
cbenitah   Tony, you are on the other hand the master of elec...   Feb 23 2006, 08:13 PM
TonyAKAVW   Well, there are a number of electrical engineers o...   Feb 23 2006, 08:29 PM
Hydra   i chose to go with Megasquirt, my thinking behind ...   Feb 24 2006, 03:32 AM
Paul Illick   Two biggest problems I see with MS are that I...   Feb 24 2006, 07:07 AM
d914   outback offers Link, stinger and then on to the bi...   Feb 24 2006, 08:20 AM
lapuwali     Feb 25 2006, 04:49 PM
Crazyhippy   http://www.914world.com/bbs2/h...   Feb 25 2006, 05:02 PM
ModPR3   <...   Feb 26 2006, 04:17 AM
Twystd1   Hey Mod, I live in OC also... Me thinks ya need ...   Feb 26 2006, 05:13 AM
Mueller     Feb 26 2006, 11:07 AM
plymouth37   first off, the 2002-2004 wrx engine is a great cho...   Feb 26 2006, 12:27 PM
ModPR3   <...   Feb 26 2006, 06:33 PM
guiltless   This has to do with wiring as well, but on a sligh...   Feb 26 2006, 09:20 PM
jd74914   theoretically that just means that their is a sens...   Feb 26 2006, 09:40 PM
Mueller   <...   Feb 26 2006, 09:48 PM
jd74914   Ok, thanks for the clarification Mike. That makes ...   Feb 26 2006, 09:54 PM
Mueller   <...   Feb 26 2006, 10:01 PM
jd74914   What would the advantage of a variable opening be,...   Feb 26 2006, 10:04 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 10:02 AM
