| BenNC |
Sep 8 2003, 10:00 PM
Member ![]() ![]() Group: Members Posts: 140 Joined: 7-February 03 From: Cary, NC Member No.: 267 |
OK, so I think that I have finally eliminated all of my starting problems except for the relay board. I get intermittant conductivity between the 1 pin on the front connector and the 6 pin on the back connector depending on which way I push the pin. What a PITA.
Since a new board is somewhat on the expensive side, what options do I have besides replacement. Thanks By the way, its been sunny with highs in the low 80's and lows in the mid 60s for the past week and my teener has been idle. (IMG:style_emoticons/default/sad.gif) |
| Brad Roberts |
Sep 8 2003, 10:10 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
Clean the female pins (pull them out of the connector) with a small wire brush. Also use the small wire brush to clean the actual male pins on the relay board. You can also "squeeze" the female pins together (be very careful and not destroy them).
B |
BenNC Starting Problem Isolated Sep 8 2003, 10:00 PM
BenNC Brad, I already cleaned everything up nicely and ... Sep 8 2003, 10:22 PM
SirAndy try to get a used one that is in good shape. i bit... Sep 8 2003, 10:28 PM
Brad Roberts Oh.. boy..
The pins on the board are soldered ont... Sep 8 2003, 10:29 PM
BenNC I played with my multimeter and the board diagram.... Sep 8 2003, 11:10 PM
Brad Roberts Ben,
If you dont have a problem with a jumper wir... Sep 8 2003, 11:18 PM![]() ![]() |
Lo-Fi Version | Time is now: 15th June 2026 - 03:40 AM |
