| ModPR3 |
Feb 23 2006, 06:34 PM
Member ![]() ![]() Group: Members Posts: 96 Joined: 7-February 06 From: Orange County, CA Member No.: 5,544 |
subie guys need your help again. after finding out that a 911 engine rebuild cost over 8k the subie or v8 path is looking good again. if i ran the 2002-2004 wrx 2.0 turbo motor what do i do about the engine control unit or engine management. can the engine be run with the stock subaru ecu or does it have to be switched out to a standalone unit. if the stock ecu can be used, how hard is it to wire into the 914. thanks.
| plymouth37 |
Feb 26 2006, 12:27 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,825 Joined: 24-May 05 From: Snoqualmie, WA Member No.: 4,138 Region Association: Pacific Northwest
first off, the 2002-2004 wrx engine is a great choice. the computers are actually interchangable between these years and require no programing to run nicely in your 914. in 2005 subaru switched to a VAT system that would have to be deprogramed from the ecu. as for wiring harnesses check out smallcarperformance.com these guys will either modify your stock harness for you or give you instructions to modify your own.
(IMG:http://www.smallcar.com/images/harness.jpg) |
ModPR3 subaru ecu/ems Feb 23 2006, 06:34 PM
lapuwali The stock ECU can be used. There's at least o... Feb 23 2006, 06:40 PM
Mueller Here you go:
Possum Link ...new board that replac... Feb 23 2006, 06:50 PM
bondo <... Feb 23 2006, 06:57 PM
lapuwali Feb 23 2006, 07:02 PM
Mueller Feb 23 2006, 07:06 PM
TonyAKAVW Type IV cheap? yeah right!
At least most S... Feb 23 2006, 07:21 PM
TonyAKAVW The wiring harness 'conversion' isn't ... Feb 23 2006, 08:02 PM
cbenitah Tony, you are on the other hand the master of elec... Feb 23 2006, 08:13 PM
TonyAKAVW Well, there are a number of electrical engineers o... Feb 23 2006, 08:29 PM
Hydra i chose to go with Megasquirt, my thinking behind ... Feb 24 2006, 03:32 AM
Paul Illick Two biggest problems I see with MS are that I... Feb 24 2006, 07:07 AM
d914 outback offers Link, stinger and then on to the bi... Feb 24 2006, 08:20 AM
lapuwali Feb 25 2006, 04:49 PM
Crazyhippy http://www.914world.com/bbs2/h... Feb 25 2006, 05:02 PM
ModPR3 <... Feb 26 2006, 04:17 AM
Twystd1 Hey Mod,
I live in OC also...
Me thinks ya need ... Feb 26 2006, 05:13 AM
Mueller ![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 10:03 AM |
