Removing front caliper pistons, Any tricks you've used in the past?? |
914zim |
Sep 9 2003, 11:23 AM
Still pretty clueless... Group: Members Posts: 221 Joined: 29-July 03 From: New Berlin, WI Member No.: 962 |
Hey guys:
I'm trying to get the pistons out of the front calipers. It looks like they're seized, but they're not too bad looking. I cannot move them by hand. I've sprayed tham with Liquid Wrench to try and loosen them up. I've used the trick to blast compressed air to remove one of them in the past, but I was wondering if you guys had any other ideas. I was thinking of just grabbing the very tops with a pliers and trying to twist and pull them out, but that didn't seem like the best idea. I do have the rebuild kits on order. Any ideas are appreciated. Andy... (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/pray.gif) |
smrz914 |
Sep 9 2003, 11:50 AM
Soon to be brightening the life of the person behind you. Group: Members Posts: 456 Joined: 21-April 03 From: Pleasant Hill, CA or Chico, CA Member No.: 596 |
My friend used compressed air once and when the piston came out it weged his thumb between it and the other side of the caliper. I've herd suggestions of using grease b/c it's not compressable. It's for a safety measure. Some kind of penetrating fluid like Marval Mystery oil might help. try pushing the piston in not out and see if it moves. if it does then try slowly going out. good luck.
Lo-Fi Version | Time is now: 2nd June 2024 - 03:39 PM |
