| ModPR3 |
Feb 23 2006, 06:34 PM
Member ![]() ![]() Group: Members Posts: 96 Joined: 7-February 06 From: Orange County, CA Member No.: 5,544 |
subie guys need your help again. after finding out that a 911 engine rebuild cost over 8k the subie or v8 path is looking good again. if i ran the 2002-2004 wrx 2.0 turbo motor what do i do about the engine control unit or engine management. can the engine be run with the stock subaru ecu or does it have to be switched out to a standalone unit. if the stock ecu can be used, how hard is it to wire into the 914. thanks.
| guiltless |
Feb 26 2006, 09:20 PM
Member ![]() ![]() Group: Members Posts: 187 Joined: 7-August 05 From: Dana Point Ca Member No.: 4,552 |
This has to do with wiring as well, but on a slightly different tangent.
The ej257 (sti) uses a "throttle-by-wire" system. Has there been any work done to use that engine in a 914 and what was done to deal with that issue? |
ModPR3 subaru ecu/ems Feb 23 2006, 06:34 PM
lapuwali The stock ECU can be used. There's at least o... Feb 23 2006, 06:40 PM
Mueller Here you go:
Possum Link ...new board that replac... Feb 23 2006, 06:50 PM
bondo <... Feb 23 2006, 06:57 PM
lapuwali Feb 23 2006, 07:02 PM
Mueller Feb 23 2006, 07:06 PM
TonyAKAVW Type IV cheap? yeah right!
At least most S... Feb 23 2006, 07:21 PM
TonyAKAVW The wiring harness 'conversion' isn't ... Feb 23 2006, 08:02 PM
cbenitah Tony, you are on the other hand the master of elec... Feb 23 2006, 08:13 PM
TonyAKAVW Well, there are a number of electrical engineers o... Feb 23 2006, 08:29 PM
Hydra i chose to go with Megasquirt, my thinking behind ... Feb 24 2006, 03:32 AM
Paul Illick Two biggest problems I see with MS are that I... Feb 24 2006, 07:07 AM
d914 outback offers Link, stinger and then on to the bi... Feb 24 2006, 08:20 AM
lapuwali Feb 25 2006, 04:49 PM
Crazyhippy http://www.914world.com/bbs2/h... Feb 25 2006, 05:02 PM
ModPR3 <... Feb 26 2006, 04:17 AM
Twystd1 Hey Mod,
I live in OC also...
Me thinks ya need ... Feb 26 2006, 05:13 AM
Mueller ![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 10:01 AM |
