> subaru ecu/ems, subaru engine electronics
ModPR3
post Feb 23 2006, 06:34 PM
subie guys need your help again. after finding out that a 911 engine rebuild cost over 8k the subie or v8 path is looking good again. if i ran the 2002-2004 wrx 2.0 turbo motor what do i do about the engine control unit or engine management. can the engine be run with the stock subaru ecu or does it have to be switched out to a standalone unit. if the stock ecu can be used, how hard is it to wire into the 914. thanks.
jd74914
post Feb 26 2006, 09:54 PM
Its alive
Ok, thanks for the clarification Mike. That makes more sense (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif)
ModPR3   subaru ecu/ems   Feb 23 2006, 06:34 PM
lapuwali   The stock ECU can be used. There's at least o...   Feb 23 2006, 06:40 PM
Mueller   Here you go: Possum Link ...new board that replac...   Feb 23 2006, 06:50 PM
bondo   <...   Feb 23 2006, 06:57 PM
lapuwali     Feb 23 2006, 07:02 PM
Mueller     Feb 23 2006, 07:06 PM
TonyAKAVW   Type IV cheap? yeah right! At least most S...   Feb 23 2006, 07:21 PM
TonyAKAVW   The wiring harness 'conversion' isn't ...   Feb 23 2006, 08:02 PM
cbenitah   Tony, you are on the other hand the master of elec...   Feb 23 2006, 08:13 PM
TonyAKAVW   Well, there are a number of electrical engineers o...   Feb 23 2006, 08:29 PM
Hydra   i chose to go with Megasquirt, my thinking behind ...   Feb 24 2006, 03:32 AM
Paul Illick   Two biggest problems I see with MS are that I...   Feb 24 2006, 07:07 AM
d914   outback offers Link, stinger and then on to the bi...   Feb 24 2006, 08:20 AM
lapuwali     Feb 25 2006, 04:49 PM
Crazyhippy   http://www.914world.com/bbs2/h...   Feb 25 2006, 05:02 PM
ModPR3   <...   Feb 26 2006, 04:17 AM
Twystd1   Hey Mod, I live in OC also... Me thinks ya need ...   Feb 26 2006, 05:13 AM
Mueller     Feb 26 2006, 11:07 AM
plymouth37   first off, the 2002-2004 wrx engine is a great cho...   Feb 26 2006, 12:27 PM
ModPR3   <...   Feb 26 2006, 06:33 PM
guiltless   This has to do with wiring as well, but on a sligh...   Feb 26 2006, 09:20 PM
jd74914   theoretically that just means that their is a sens...   Feb 26 2006, 09:40 PM
Mueller   <...   Feb 26 2006, 09:48 PM
Mueller   <...   Feb 26 2006, 10:01 PM
jd74914   What would the advantage of a variable opening be,...   Feb 26 2006, 10:04 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 10:03 AM
