> Suspension swap, Swap 911/930 front suspension to my 914
spyder9014
post Feb 9 2003, 02:14 PM
What are the benefits of using 911/930 front suspension on a 914.
I have installed gas shocks, turbo tie rods but I have seen it recommended to use the 930 front suspension. Is this just to get the brakes or is this for struts/brakes/torsion bars?
If I upgrade the calipers and rotors will it be just as good as a complete swap?
pnewman
post Mar 4 2006, 09:04 PM
QUOTE(brant @ Mar 4 2006, 05:41 PM)
QUOTE(pnewman @ Mar 4 2006, 06:20 PM)
QUOTE(Jeroen @ Feb 9 2003, 06:32 PM)
Early 911 struts have 3" caliper mount spacing as well
And I believe you can get torsionbars for the 914 a-arms up to 23mm
cheers,
Jeroen
what size torsion bars come in oem 911 a arms? 21 mm?
thanks
19mm
question: I have 180 lb rear coil springs, rear oem sway bar, front oem sway bar, and am converting to 911 struts (I was told that the struts were out of a 1988 no a arms included.)
What size front torsion springs should I go with 21mm?
I think that I swapt out my oem's w/ a pair of used 18 or 19 mms about 6 yrs ago. Just trying to get a good balance. Were oem torsion springs for all 911's incl. 1988 19mm?
thanks, Pete (IMG:style_emoticons/default/beer.gif)
spyder9014   Suspension swap   Feb 9 2003, 02:14 PM
J P Stein   Most guys do the 9eleben front end to get bigger b...   Feb 9 2003, 02:51 PM
Jeroen   Early 911 struts have 3" caliper mount spacing as ...   Feb 9 2003, 08:32 PM
Mueller   IMHO.....swapping over to the 930 front end and pa...   Feb 9 2003, 10:52 PM
pnewman     Mar 4 2006, 07:20 PM
brant     Mar 4 2006, 07:41 PM
pnewman     Mar 4 2006, 09:04 PM
Spoke   I converted my 71 914 to 911 a-arms, torsion bars,...   Mar 4 2006, 10:37 PM
brant   All 911's were 19mm in fact its not even reall...   Mar 4 2006, 10:39 PM
army dude   http://www.914world.com/bbs2/h...   Mar 4 2006, 10:49 PM
Aaron Cox     Mar 4 2006, 10:59 PM
Dr. Roger     Mar 4 2006, 11:00 PM
Dr. Roger   prolly swap in some new brake lines while it's...   Mar 4 2006, 11:06 PM
brant   Pete, 19mm would be a good match for 180 rear sp...   Mar 5 2006, 09:24 AM
pnewman     Mar 5 2006, 10:00 AM
brant     Mar 5 2006, 10:34 AM
pnewman   Brant, thanks for the info! h...   Mar 5 2006, 12:04 PM
pnewman   Brant, Final front end suspension. 1988 stru...   Mar 25 2006, 08:28 PM
brant   sounds like you've worked your butt off... tha...   Mar 25 2006, 09:33 PM
Eric_Shea   Bolt on Army Dude, Bolt on.   Mar 25 2006, 10:14 PM
pnewman   Hey Eric! I pressed in your hubs. They are r...   Mar 26 2006, 12:07 AM
Eric_Shea   Glad everything is working out... <...   Mar 26 2006, 08:01 AM
rickyhgarcia   Elephant racing has a great tool in their website ...   Mar 26 2006, 11:27 AM
Dr. Roger   <...   Mar 26 2006, 11:28 AM
rickyhgarcia   Can also check in here: Struts spindler mods...   Mar 27 2006, 11:49 AM
Dr. Roger   andyrew, did u notice on elephants website that t...   Mar 27 2006, 02:45 PM
rickyhgarcia   225lbs...275lbs rear springs? On a lightweight ca...   Mar 31 2006, 05:50 PM
Mueller
  Mar 31 2006, 11:29 PM
rickyhgarcia   Koni Inserts P/N 914/914-6 8641-1077 911 75-8...   Mar 31 2006, 11:30 PM
Eric_Shea
  Mar 31 2006, 11:39 PM
Eric_Shea
  Mar 31 2006, 11:42 PM
rickyhgarcia
  Mar 31 2006, 11:47 PM
Eric_Shea
  Mar 31 2006, 11:48 PM
rickyhgarcia
  Mar 31 2006, 11:58 PM
rickyhgarcia
  Apr 1 2006, 12:15 AM
Eric_Shea
  Apr 1 2006, 12:25 AM
rickyhgarcia
  Apr 1 2006, 12:33 AM
Eric_Shea
  Apr 1 2006, 12:34 AM
army dude   http://www.914world.com/bbs2/h...   Apr 1 2006, 12:50 AM
rickyhgarcia
  Apr 1 2006, 12:56 AM
rickyhgarcia
  Apr 1 2006, 01:35 AM
Eric_Shea   Thanks Ricky for the explanation. Again, as evi...   Apr 1 2006, 11:17 AM
rickyhgarcia
  Apr 1 2006, 12:19 PM
GTPatrick   Eric & Ricky, . . . . . What do you guys mea...   Apr 1 2006, 12:39 PM
rickyhgarcia   ...   Apr 1 2006, 01:03 PM
rickyhgarcia
  Apr 1 2006, 01:33 PM
John Jentz   ...   Apr 1 2006, 02:11 PM
Eric_Shea
  Apr 1 2006, 03:17 PM
soupbone   So the question for me is who can do custom valved...   Apr 2 2006, 01:43 AM
neo914-6
  Apr 2 2006, 02:56 AM
jasons   <...   Apr 2 2006, 08:25 AM
Eric_Shea   Try Jack French at Bilstein he can be reached at 1...   Apr 2 2006, 10:06 AM
rickyhgarcia
  Apr 2 2006, 07:04 PM
Eric_Shea
  Apr 2 2006, 07:58 PM
jsteele22   Just came across this thread. Lots of great info....   Apr 2 2006, 09:24 PM
rickyhgarcia
  Apr 2 2006, 10:12 PM
neo914-6   ...   Apr 3 2006, 09:51 AM
rickyhgarcia
  Apr 3 2006, 09:58 AM
Eric_Shea   http://www.914world.com/bbs2/h...   Apr 3 2006, 09:59 AM
JOHNMAN
  Apr 3 2006, 10:41 AM
Eric_Shea   See the bottom of page 3.   Apr 3 2006, 10:54 AM
Eric_Shea   I also want to be clear on the pricing for revalvi...   Apr 3 2006, 11:06 AM
JOHNMAN   Thanks for the info Eric, I read and re-read the ...   Apr 3 2006, 11:25 AM
Eric_Shea
  Apr 3 2006, 11:30 AM
JOHNMAN   We thank you for your support.   Apr 3 2006, 11:32 AM
rickyhgarcia   This is what they look like before powder coating....   Apr 3 2006, 12:05 PM
rickyhgarcia   Left...   Apr 3 2006, 12:10 PM
rickyhgarcia   Right...   Apr 3 2006, 12:11 PM
Eric_Shea   Pur-deeeeee http://www.914world.co...   Apr 3 2006, 01:19 PM
davep   There are quite a few struts used on the 911 and 9...   Apr 3 2006, 01:46 PM
soupbone   ...   Apr 3 2006, 03:45 PM
Eric_Shea   That's basically it. He does a really nice jo...   Apr 3 2006, 03:55 PM
rickyhgarcia   Some general information on 911 struts and front b...   Apr 4 2006, 05:41 AM
rickyhgarcia   Some more general info:   Apr 4 2006, 06:04 AM
- Lo-Fi Version Time is now: 9th June 2026 - 09:41 AM
