> someone please write a dissertation on LSD's, Quaife, ZF, torsen, lockers, phantom's..
Aaron Cox
post Mar 4 2006, 09:53 PM
Professional Tinkerer
blows my mind... im interested in how each one works, and the effects of it on acceleration (lock unlock etc) for each of them....
would be a great wealth of knowledge to have in one place....
bueller?
alpha434
post Mar 4 2006, 10:35 PM
My member number is no coincidence.
QUOTE (Aaron Cox @ Mar 4 2006, 08:30 PM)
QUOTE (pek771 @ Mar 4 2006, 09:20 PM)
http://auto.howstuffworks.com/differential.htm
The basics. I'm curious about this Phantom Grip deal.
just read the whole thing... knew most of it...
now id like to learn about each one's behavior in accel/decel conditions... and cornering
Glad you asked.
PG: Can't power through the corners or the diffs will lock
LS: Easy to set proper spring pressure for cornering.
Locked:Have to be able to break the tires loose, or you'll push yourself off the track.
Opem:Best cornering, since the axles are free to change speeds. Hurts you on the straights, where you've only got one wheel driving you at any given time.
Aaron Cox   someone please write a dissertation on LSD's   Mar 4 2006, 09:53 PM
TimT   http://www.914world.com/bbs2/h...   Mar 4 2006, 09:56 PM
Aaron Cox   tim, you can sing about LSD's if thats your st...   Mar 4 2006, 09:57 PM
TimT   Not sure what your looking for exactly... As LSDs...   Mar 4 2006, 10:01 PM
SLITS   1. Put tiny piece of designed square paper onto to...   Mar 4 2006, 10:02 PM
Aaron Cox     Mar 4 2006, 10:02 PM
J P Stein   The only thing I know about LSDs is that I have ha...   Mar 4 2006, 10:11 PM
pek771   http://auto.howstuffworks.com/differential.htm Th...   Mar 4 2006, 10:20 PM
Aaron Cox     Mar 4 2006, 10:30 PM
alpha434   Dude. Where's the young gun action? You have t...   Mar 4 2006, 10:31 PM
alpha434   ...   Mar 4 2006, 10:35 PM
pek771   Regarding the Phantom Grip... I looked at their we...   Mar 4 2006, 11:01 PM
bondo     Mar 4 2006, 11:06 PM
alpha434   Could be. I've actually never worked on an ame...   Mar 4 2006, 11:10 PM
bondo   Limited slip Locker   Mar 4 2006, 11:12 PM
alpha434   Yeah. My definition of posi-trac was hearsay from ...   Mar 4 2006, 11:20 PM
Dr. Roger   one strange thing about lockers is that if you go ...   Mar 4 2006, 11:29 PM
alpha434   ...   Mar 4 2006, 11:33 PM
sixnotfour   18 types to choose from;Use the "select diiff. " b...   Mar 4 2006, 11:38 PM
pek771   It seems the useful combinations we would consider...   Mar 4 2006, 11:47 PM
campbellcj   There have been a bunch of detailed differential t...   Mar 5 2006, 12:00 AM
KenH   Arron - not sure I can answer all, or any of your ...   Mar 5 2006, 01:51 AM
brant     Mar 5 2006, 07:58 AM
brant   One more thing.. in a conversation with Paul Guard...   Mar 5 2006, 08:24 AM
kdfoust   I've made my descision for my big track car (9...   Mar 5 2006, 03:11 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 09:42 AM
