One fix leads to, another problem |
BenNC |
Sep 11 2003, 11:43 AM
Member Group: Members Posts: 140 Joined: 7-February 03 From: Cary, NC Member No.: 267 |
OK, so I've got good connection all the way to the starter. Turns like a champ now.
However, now I'm not getting spark. As part of this exercise I burned up my Pertronix and had to put the points back in. There's a little braided copper wire in the distributor that is attached to the breaker plate on one end and air on the other. I'm guessing that this is the ground wired described in a PP tech article for ignition troubleshooting. Where does this need to go to, body of distributor? How should I attach it. It's a good thing that I enjoy this stuff or I'd be going nuts. Thanks, |
RustyWa |
Sep 11 2003, 12:00 PM
Working Member Group: Members Posts: 610 Joined: 2-January 03 From: Kent, WA Member No.: 72 |
Ouch....it should be attached to the plates inside the distributer on both sides. Probably would be cheaper to just buy a rebuilt A-1 Cardon unit from the FLAPS than to buy the replacement plates with a good ground connection.
Lo-Fi Version | Time is now: 12th June 2024 - 08:13 AM |
