| yarin |
Mar 12 2006, 09:45 PM
'14-X'in FOOL ![]() ![]() ![]() Group: Members Posts: 988 Joined: 13-May 03 From: Guttenberg, NJ Member No.: 693 Region Association: North East States |
For you MS guys using a relax box where did you mount the brain?
I bought the 12' unterminated relay cable from DIYautotune. I'd like to mount the box under the dash, but 12' isn't enough to reach. I mounted my relay box next to the stock relay box. I'll measure again tomorrow, but i'm pretty sure it wont make it. Where did you guys mount your MS box? I thought about mounting it in the middle of the firewall between the two seats, but I don't want to expose it to direct sunlight. I know the compnents on MS II are OK to higher temps, but I see no reason to expose it to high temps. My next idea was to mount it inbetween the seats on top of the tunnel. But I know that the when someone releases a 5 pt harness one of the belt is going to smack the unit. Any other ideas? |
Mueller Mar 12 2006, 09:58 PM
yarin Is the stock location OK given the mechanical and ... Mar 12 2006, 10:06 PM
jkeyzer I'm planning to put mine in between the seats.... Mar 12 2006, 11:02 PM
TimT mount the brain inside the cockpit... Mar 12 2006, 11:08 PM
DNHunt Mine is in the center console. I can't believe... Mar 13 2006, 07:56 AM
yarin Mar 13 2006, 10:52 AM
lapuwali I have a partially assembled MSv2.2 on my workbenc... Mar 13 2006, 11:58 AM
DNHunt One thing to consider. Take the DB9 serial port of... Mar 13 2006, 01:49 PM
yarin Thanks guys. I think I've decided to mount it ... Mar 13 2006, 02:20 PM![]() ![]() |
Lo-Fi Version | Time is now: 16th June 2026 - 03:41 AM |
