> Megasquirt mounting location, where?
yarin
post Mar 12 2006, 09:45 PM
'14-X'in FOOL
For you MS guys using a relax box where did you mount the brain?
I bought the 12' unterminated relay cable from DIYautotune. I'd like to mount the box under the dash, but 12' isn't enough to reach. I mounted my relay box next to the stock relay box. I'll measure again tomorrow, but i'm pretty sure it wont make it.
Where did you guys mount your MS box? I thought about mounting it in the middle of the firewall between the two seats, but I don't want to expose it to direct sunlight. I know the compnents on MS II are OK to higher temps, but I see no reason to expose it to high temps. My next idea was to mount it inbetween the seats on top of the tunnel. But I know that the when someone releases a 5 pt harness one of the belt is going to smack the unit.
Any other ideas?
DNHunt
post Mar 13 2006, 07:56 AM
914 Wizard? No way. I got too much to learn.
Mine is in the center console. I can't believe a 12' cable is not longe enough. It's dry, cool and quiet. I made my own cable. Incidentally, I sheilded the tach signal all the way to the ECU.
Dave
- Lo-Fi Version Time is now: 16th June 2026 - 02:40 AM
