roll bar trim |
roll bar trim |
sk8kat1 |
Mar 13 2006, 02:44 PM
Senior Member Group: Members Posts: 911 Joined: 10-October 05 From: belvidere ,IL Member No.: 4,937 |
so I am tring to remove the roll bar chrome trim .. I finally figure out that there is a little nut on the underside of the fender well ....what I also discovered is that it is a bitch to get to and it is a bit rusted
any hints as to a good way to get the little bugger off ? |
toon1 |
Mar 13 2006, 03:53 PM
Senior Member Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
Just did mine this past w/e. Replaced the rear window seal.
once all the screws are removed and the side trim where the seat belts attach you can pull on it. Don't pull too hard, wiggle it up and down while pulling out. Be careful of the targs top levers. It should come out. good luck..... |
Lo-Fi Version | Time is now: 9th June 2024 - 06:29 PM |
