Insanely tight rear hub nut.. HELP! |
mrdezyne |
Mar 13 2006, 04:48 PM
Now on larger rolling jack stands! Group: Members Posts: 468 Joined: 31-July 05 From: Tulsa, OK Member No.: 4,510 |
Trying to tear down my rear brakes and suspension to start a rebuild but I have hit a stone wall with the hub nuts on both sides. Are these things torqued with a 3ft cheater bar or something? I have already tried penetrating oil and heat cycles. The threads are not rusty nor are the nuts. Nothing is rounded off..... yet. Is there a secret here or what?
Eric_Shea |
Mar 13 2006, 05:13 PM
PMB Performance Group: Admin Posts: 19,275 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
I've gotten all mine off with the impact.
I do them off the car too. I have a large piece of aluminum that I bolt to the hub using a couple lug bolts. That stabilizes it. Then I prop the MAPP torch in such a way that it blasts the nut for about 5 minutes. I've only had one that I had to use acetylene on. We got it cherry red and it finally came off. Proper amounts of serious heat seem to be the ticket. Cheater bars should do the trick. |
Lo-Fi Version | Time is now: 23rd May 2024 - 12:38 PM |
